Old 09-09-2015, 08:41 PM   #1
Power to RV won't work. PLEASE HELP!
I just purchased a 2010 Coachmen Freedom Express 300BHS. When I was at the sellers home checking it out everything seemed to work fine. When I got it home I ran a 12 gauge extension cord to plug it in to a GFI outlet and the outlet immediately tripped every time. I then plugged it into a regular adapter and it didn't trip anything, but nothing worked in the camper. I realized at that point that it was still plugged into the truck where we were initially running it off of the 12v. I'm not sure if that would have messed anything up. After I unplugged it from the truck I found the breaker box in the trailer and flipped everything off, plugged it into the GFI outlet again, and turned on things one at a time. The only thing that didn't immediately flip the outlet was the microwave, which came on, but when I tried to use it it would again flip the outlet. When I turned the AC breaker on by itself nothing flipped, but it also didn't work, as if it wasn't even trying to work. I have no clue what is going on, or if I'm doing something wrong, or if I possible messed something up by not unplugging it from the truck before plugging it into the outlet. Can anyone give me something information on what might be going on?
jch2122 is offline   Reply With Quote
Old 09-09-2015, 08:57 PM   #2
DDC
DDC's Avatar
The rv has GFI's so you don't plug into another GFI, it will not work, so make sure you are not plugging into one that is also being fed from anotherGFI. Hope this helps.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-09-2015, 09:00 PM   #3
I don't really know much about campers, as this is my first. The breaker has a switch for GFCI, is that the same thing basically as GFI? I tried that both ways if it makes a difference. I tried it with a regular outlet as well and it didn't work.
Old 09-09-2015, 09:09 PM   #4
Flybob's Avatar
Make sure you do not have the water heater electric switch turned on with no water in it. It will burn out the element immediately. A burned WH element can cause a GFI to trip.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-09-2015, 09:12 PM   #5
You didn't say how much power the outlet provides? If not at least 20 amp you could damage the A/C by trying to run it with insufficient power for boot up. You might want to go to the forum electrical section for articles on AC and DC power, amp draw, etc.
Very informative.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-09-2015, 09:13 PM   #6
The house gfci will trip because the trailer is not grounded. If you reset it, it should work. However, as stated above, I would not recommend using a gfci outlet.
Did you check to see if the inverter breaker on the trailer also tripped?
Krawler is offline   Reply With Quote
Old 09-09-2015, 09:15 PM   #7
Krawler, what is the inverter breaker? The only breakers I saw on the trailer were a main breaker, and 5 other breakers for the fridge, ac, gfci, microwave, and water heater.
Old 09-09-2015, 09:24 PM   #8
Mr. Dan's Avatar
I ALWAYS plug my trailer into a 15a plug on a GFCI circuit in my garage when I am loading it for a trip. I ALWAYS use a 50' 12 awg extension cord. It ALWAYS works right. I never run the A/C on this set-up.
Not all trailers have an inverter. Mine doesn't. Mine DOES have a converter.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 09-09-2015, 09:24 PM   #9
You don't have a breaker in the elec panel for the inverter? If you are getting no power at all, try turning the main off for a couple seconds, before throwing back on.
Old 09-09-2015, 09:26 PM   #10
bikendan's Avatar
Krawler meant the CONVERTER, not inverter.
Your trailer doesn't come with an INverter, unless a previous owner installed one.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
power
