Old 11-12-2014, 06:05 PM   #11
Thanks TURBS!
huffmanba is offline   Reply With Quote
Old 11-12-2014, 06:47 PM   #12
Jerry01's Avatar
Originally Posted by Brockinfla View Post
You probably do not have a pure sine converter.
I thought that only applied to inverters, not convertors. If he is plugged into shore power, the convertor should just pass the AC voltage. Someone correct me if I am wrong. Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 11-12-2014, 06:55 PM   #13
wmtire's Avatar
Let me see if I'm following correct. You said you were able to charge using a DC outlet, which I am assuming is a USB outlet. If this is correct, then you must be using a usb cord.
I am also assuming that if you are using the 120 volt outlets, then you must also be using the usb cord plugged into a 120 volt adapter.
If this is also correct, are you using this same 120 volt adapter on all the electronics.....and could that one part be the problem?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-12-2014, 07:57 PM   #14
You are absolutely correct. I apologize for indicating converter when I most certainly meant inverter.
Brockinfla is offline   Reply With Quote
Old 11-13-2014, 07:18 AM   #15
Something isn't adding up if he's plugged in to the power pole, since yes, that power just gets passed along to the outlets.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-13-2014, 07:30 AM   #16
TURBS's Avatar
I'd check the power with a multimeter @ the outlet just to see what it is.
TURBS.
Old 11-13-2014, 09:12 AM   #17
mTn_biKer65's Avatar
We've had erratic success with charging some of our electronic devices as well when connected to shore power. Adapters that would normally work at home don't work in the travel trailer. I assume the adapters are just overly sensitive to the current they're receiving and won't pass it on to the devices. That said we do have one go to adapter that came with our Blackberry Playbook that works for all 5 of our devices (2 Blackberry, 1 Samsung, 1 HTC and 1 ASUS). Makes for some charger scheduling issues but for the most part we can work around them.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 11-13-2014, 09:15 AM   #18
TURBS's Avatar
I've never had an issue either on shore power or on gennie.
Ipads,ipods,I phones and androids.
TURBS.
Old 11-14-2014, 07:42 PM   #19
It isn't a problem with current, current is pulled by each device. Voltage is pushed.
Is it on all outlets or just 1 or 2? Have you tried your chargers directly plugged into the power pole outside?
I'm taking a stab in the dark, but I wonder if your camper has a modified sine wave inverter that is permanently attached to the outlets you have a problem with, and it has very dirty output. So even when plugged into the power pole it is feeding something to those outlets that the chargers just can't handle (and the inverter is running from the 12 volt feed from the converter). It isn't unheard-of to have this setup in a camper so you don't have to add a transfer switch.
2010 Chevy Suburban
Old 11-15-2014, 08:41 AM   #20
HONDAMAN174's Avatar
Oddly enough, my iPhone will not charge from the usb/12v station. Have to grab an adapter to work correctly.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
charging
