Old 07-11-2018, 04:00 PM   #21
Also, the date may be stamped on the back of the detector. Sniff around your battery. Mine was off gassing and seeing off the alarm, although it did not need the assistance of the A/C,
AbdRahim is offline   Reply With Quote
Old 07-14-2018, 09:34 PM   #22
You might have a refrigerant leak
Kuba is offline   Reply With Quote
Old 07-14-2018, 09:35 PM   #23
I do HVAC for living. My gas sniffer goes off on freon leaks
Old 09-18-2018, 06:48 PM   #24
Kirk S's Avatar
Originally Posted by Delco Bobby View Post
You got some good answers but dust and non propane and non CO gas can set off these alarms, since you said it happens when the AC comes on I suspect something other than propane is causing the alarm.
I don’t want to minimize the danger of propane or CO but you may have another cause especially if the alarm only occurs when running your AC.
A few days ago while driving at highway speeds my alarm was sounding for about 20 minutes then stopped. Not positive as to what caused it but that has happened a few times before. No alarm during next 3 hours of driving.
Our CO alarm sounded intermittently while going down the highway. Even though I realize CO has no odor, I couldn't help but think it was caused by the unpleasant exhaust odor of a vehicle ahead of us. Once we exited the highway the alarm didn't sound again and hasn't since.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 09-18-2018, 07:10 PM   #25
waybeck2018
waybeck2018's Avatar
The newer detectors from the past 8-10 years have a service life of 5 years. Once that date is reached from manufacture date the alarms will continue to sound off. Mine started intermittently for a week or two, then stopped. After that, a continual beep. I suggest you remove it and check the manufacture date. If it is past five years old splurge for a new detector. It could result in money well spent if a real event happens.
waybeck2018 is offline   Reply With Quote
propane
