01-21-2012, 03:50 PM
Question about slide outs
i have a 2007 forest river sierra with 4 slides and after a few days of it in storage i have to go back and check because some of the slides have inched there way out? does anyone know what causes this and how i can fix it thanks
01-21-2012, 04:04 PM
Never heard of such a thing? Is this a hydraulic or electric system?
Turn everything off and disconnect the batter. See if that helps?
01-21-2012, 04:22 PM
That is a new one on me too. I am subscribing to the thread so I won't miss the answer. I am guessing it is a hydraulic system and there is a leaking seal.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
2012 outings California Jackson - 3 nights, New Melones Lake - 2, Lewiston Lake - 4
01-21-2012, 05:22 PM
they only come out a inch or so and i keep the battery disconected when in storage they are hydralic
01-21-2012, 05:45 PM
Moderators' Assistant
i have an electric slideout but a hydraulic leak sounds likely.
Dan and Shawn and Zoe the Wonder Dog
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
01-21-2012, 10:04 PM
Hydraulic leaks seems to make no sense to me, The ram should be fully retracted when the slides are closed? So no fluid in the cylinder. I'm guessing that there is a sticky valve that is not fully releasing to relieve the pressure in the line. Therefore the cylinder is being pushed out as the pressure leaks past. To test it, I would swap the lines around and see if when doing so another slide moves.
01-21-2012, 11:55 PM
2007 WildCat 32QBBS
Somewhere it's passing fluid. Each hydraulic cylinder has 2 hoses, one for each side of the internal piston. For the slide to move out it has to be loosing pressure on the one line that pressurizes to pull the slide in.
[IMG]http://rds.yahoo.com/_ylt=A0PDoX62pRtP6EsA6tmjzbkF;_ylu=X3oDMTBtdXFkOWt hBHNlYwNmcC1hdHRyaWIEc2xrA2ZpbWc-/SIG=135jjd2jl/EXP=1327240758/**http%3a//www.hydrauliconline.com/wp-content/uploads/2009/05/hyd-cylinder-simple.gif[/IMG]
1987 F350 Crew Cab Dually 6.9 turbo diesel
01-22-2012, 05:28 AM
87CrewDually's suggestion makes sense to me. It could be that you need to replace some o-rings? If you replace o-rings, use those that have a 70 durometer rating. I would inspect all the system components for signs of leakage. Is it the same slides doing each time or is all 4 prone to do it with only some of them doing it each time? Did the problem start with 1 slide or did it start with multiple slides?
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
01-22-2012, 10:43 PM
all the slides do it and it never loses any fluid
01-22-2012, 11:43 PM
2007 WildCat 32QBBS
O.K. If they are all doing it, then I would suspect the solinoid valve isn't holding the pressure and it's losing the pressure to hold the slides in. (not leaking fluid externally, but internally)
The solinoid will have a thumb valve on it to bypass it manually. It should be near the pump. IIRC it should be turned counter clock-wise. I can check tomorrow for sure or some one else can chime in.
Also check here if you have a Lippert unit.
http://www.lci1.com/index.php?option...=38&Itemid=103
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 672 |
| 148 members and 524 guests |
| 11XLITE28BH, 4bnabird, 64c10, alphadog99, alpinemike, autorot8, Bigmatt, BigR, bikendan, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Capsfloyd, carsonizik3, Cascade Bob, cdbus, ChrisZazzara, Cowracer, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, dapersico, davidjb, daw592, depo, Derekcan, djorgensen3, dnaraG_1M, doc73, donh, donn, doosterhouse, drobert, DTingle, dunnnc, EL99jl, emljr, Emptypockets, extremebike, Falcon35, feerobk, Fire Instructor, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, grhodes50, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itat, itech, Itsthetwoofus, Janet H, jar3316, JedinWI, jjm901, jkinger, jmswms, jobren4, Juan.Cortes, ken0042, Kevin-and-Julie, KKapa, KoolAide, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, Loopyhamil, LuckyMcBRIDE, mbfree66, mhartzel, Michigan, Mickey1, mike2tall, mike54, Mrgary, NanaKaren, NINA, Nursx2, papap, pgordemer, pg_rider, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, pwadini, RattVader, rbrandon, Redheaded blue tick, Retired63, rgmiller32, rick51, rickthelen, RJHuser, rob2112, Sahgie, SDENN4281, shane1234, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, sphinx, T.Kott, Tee, Test Account, tmmar, trailraider, travyp, Triguy, trudinator, True Believer, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, washdweller, wellcoman, whj77372, Wildcat Chris, wnytaxman, y01lxb |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
