Old 01-05-2015, 11:29 AM   #1
Re-winterizing
Had my Lacrosse TT winterized by my dealer. Took it down to NC over the holidays and used the toilet only. Didn't hook up the water line or run the pump. Dumped water straight into the toilet. When I dumped the black tank I did hook up the flush for it to the water spicket. When I got back to PA I dumped a gallon of RV antifreeze into the toilet and black tank (left some in to help seal it). Should I be doing anything else? First Rv and first post.
TomGraham is offline   Reply With Quote
Old 01-05-2015, 12:54 PM   #2
Evereddie's Avatar
You should blow out the flush system you used. But in the case of that flush only you can probably suck the water out with a shop vac. Just hold the hose up to the inlet for a minute. Or, fill the end of a water hose with anti freeze and flow that into the flush system.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 01-05-2015, 01:01 PM   #3
Ford Idaho's Avatar
If you shopvac has an exhaust port use it otherwise as Evereddie suggested.
winter, winterize
