Old 02-10-2012, 07:15 PM   #11
Freds342's Avatar
Marine 12-V lamps have two nipples. The "shell" is isolated from the filament, and the connection to the filament is thru the two nipples.
If one of these is replaced with an automotive, dual filament lamp, it will cause exactly this problem.
Perhaps they installed marine lamps in this Palomino?
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 02-12-2012, 10:59 PM   #12
jimh's Avatar
my first thought was ground but if all was working properly and the bulbs just burnt out, i would say u used the wrong type replacement bulb. try removing a bulb from one of the other lamps and installing it in socket that had the burnt out one and see if the problem goes away.
if u had a short, i would suspect a fuse to blow.
when u swap bulbs around, leave the socket empty that u pull the bulb from. if all works, then make note of the number on the bulb and replace with that type.
the bulbs can be bought at an automotive store but the ones used in RVs have a different number and run cooler. the automotive light will work but if u have close fitting plastic covers over the lights, they will melt them.
jimh is offline   Reply With Quote
Old 02-13-2012, 08:06 AM   #13
1157 bulb vs. 1156 bulb
1157 should have offset pins for dual elements (turn signal and running light)
1156 should only have one element with even pins
Rich, Steph, Ava, & Micah
2010 Sierra 1500 SLE Z60
2011 Shasta Revere 30 CKBH
RichieD is offline   Reply With Quote
Old 02-13-2012, 08:21 AM   #14
realebill's Avatar
bulbs in all the light fixtures in my older rv were #1141. single contact,12vt.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
