Old 02-08-2012, 01:35 PM   #1
Really weird electrical issue
I have a 2011 Palomono Sabre 32BHOK. It has a lamp mounted on the wall behind the sofa. Both bulbs burned out. They are the bulbs that you put in and make a 1/4 twist to set. They have the 2 small nipples on them. Anyway...I get new bulbs and put them in. When I hit the switch to turn them on, the light over the dinette and the light over the couch turn off. The lamp does nothing. I hit the switch again and both of those come on. I remove the bulbs and everything works normally.
What gives?????
ndtiger is offline   Reply With Quote
Old 02-08-2012, 01:38 PM   #2
Are the nipples different distances from the end of the bulb? Are you sure you are installing the bulb correctly if the distance is different? Sounds like they are inserted wrong and it's shorting out the other lights.
Len & Cheri is offline   Reply With Quote
Old 02-08-2012, 01:47 PM   #3
Is it like the nipples on this bulb (circled area)?
Old 02-08-2012, 01:48 PM   #4
i will have to check when I get home Are they all like that or just some? I got mine at home depot under lanscape lighting. I have used thee for the outside lights before
Old 02-08-2012, 01:59 PM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
The bulbs used should be 12 Volt bulbs found in the Automotive areas in WalMart or any Auto parts store. There are numbers on the side of the bulb and the replacement should have the same number. Landscaping Bulbs being used may be the reason for the Weird Occurrences.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-08-2012, 04:02 PM   #6
TURBS's Avatar
Sounds to me like a ground.
Old 02-08-2012, 04:33 PM   #7
Most bulbs in that type of light only have one element - if you are using the type pictured that is probably your problem.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 02-08-2012, 05:06 PM   #8
True, it should be a single element bulb. Can't remember if I've ever seen a single element with offset nipples.
Old 02-08-2012, 05:19 PM   #9
Retired truck driver here & I have never seen a single element bulb with off set nipples either.
Old 02-09-2012, 01:10 AM   #10
Drinkin beer on the beach
Rod Johnson's Avatar
yep, because the dual element bulbs have different wattage filaments, like say a 3W running light and a 7W turnsignal. The nipples keep you from putting it in wrong and having the wrong filament light up.
We've seen it happen though. Driving down the street at night behind somebody. All of their tail lights are on, except one is really bright. Thats because he got the bulb jammed in socket wrong.
Hope for the original poster that its the wrong bulbs, that would be an easy fix.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
