Old 07-20-2012, 07:59 AM   #1
mike54's Avatar
Cool reason for satellite not working update
Wednesday was first time I hooked up my satellite to my yr old rockwood 8319 and I couldn't get signal so I ran the cable out the window and the tv cable direcly to the tv had the satellite signal in minutes
Today Friday I decided to find out why there is no signal thru the rv cables I took the plate off the inside the cabinet cables are all loose so I tighten them still no signal. I pull the outside box guess what I find ??????
both cables are there but not hooked up I get them tightened up go inside I got a picture but it is very snowy and the amp is off I wiggle the plate picture gets clear I let it go the picture gets snowy again so I wiggle the plate again it clears up this time when I let it stays clear but if I move it it get snowy so the plate has a loose circuit or is bad.
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 07-20-2012, 08:13 AM   #2
TURBS's Avatar
So is it the pass through union that is the issue or one of the ends of coax hooking to it do u think?
Old 07-20-2012, 09:01 AM   #3
mike54's Avatar
no it's one of the power wire to the circuit board causing the snowy screen if I wiggle the wire it cleans up until I move it again.
this is the wall power plate I have Amazon.com: Winegard RV-7542 White Wall Plate Power Supply: Automotive
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Mike & Marsha
Old 07-20-2012, 10:21 AM   #4
TURBS's Avatar
Same as mine.
Old 07-20-2012, 10:49 AM   #5
Herk7769's Avatar
here is the manual for your plate.
HAM CALLSIGN - KC3FFW
