Old 09-21-2011, 07:16 PM   #11
Eric F.'s Avatar
That is strange. Your original post said three outlets total. Which one went out first and did it just stop or was there anything that may have caused it?
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 09-21-2011, 07:17 PM   #12
Lottery Non-Winner
Ovair's Avatar
Okay, there's a clue in your description.
All outside sockets should be looped to a GFCI, and any interior sockets that are near water (bathroom, kitchen sink) should be likewise. So if "some" are working and some are not, then I would suspect an "open" circuit as KyDan has described.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 09-21-2011, 07:17 PM   #13
sherdep's Avatar
also check the breaker panel - I have had a GFI trip and the breaker at the same time.
If that doesnt work you can take a meter and verify voltage at the plug - could have a wire that came loose causing the other outlets to quit working also
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 09-21-2011, 07:25 PM   #14
Eric, the first one that went out was the one beside the couch.
Jeff514 is offline   Reply With Quote
Old 09-21-2011, 07:33 PM   #15
Eric F.'s Avatar
Is that closest to the converter as far as the ones not working? Or the farthest?
Eric F.
2012 Ford F250
Old 09-21-2011, 07:48 PM   #16
fonzie's Avatar
Open all your breakers at the panel and close them again. The handle may look closed but it is actually tripped.....let us know.
Fonzie
Old 09-21-2011, 07:52 PM   #17
Close to to the converter.
Old 09-21-2011, 07:57 PM   #18
Eric F.'s Avatar
I would re-check all the breakers and then pull out the volt ohm meter. Check the outlet, then unscrew it and check the wires themselves. Electrical gremlins are loads of fun.
Eric F.
2012 Ford F250
Old 09-21-2011, 08:03 PM   #19
sherdep's Avatar
yes they are - I have found going to the one that works and check it then go to the next closest one usually finds the issue quick
Old 09-21-2011, 08:37 PM   #20
Eric F.'s Avatar
I would start by shutting off all the breakers. Turn them on one by one and find out if the faulty ones are on the same circuit. Then start with the outlet the farthest from the converter and move towards it. They will most likely be piggybacked all the way from the converter. Hopefully it is a bad outlet in the chain and the ones feeding off it are being affected.
Good luck
Eric F.
2012 Ford F250
