Old 12-02-2015, 05:33 PM   #11
AquaMan's Avatar
Originally Posted by TURBS View Post
Yes.
And no. Lippert does not recommend installing them on hydraulic landing gear and have gone as far as saying your warranty may be voided, but they also sell the adapters to install them. Doesn't make much sense to me.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-02-2015, 07:14 PM   #12
arpipeliner's Avatar
CYA policy. Some people wouldn't understand that hydraulic shears are used to cut scrap steel. Imagine a locked stabilizer and hydraulic cyclinder vs LCI frame with a person not knowing when to stop.
Don't have auto level on my camper but could see a holy nightmare if you had it set up with stabilizers and accidentally the relevel button got pushed and it went thru a cycle. I hear it's not supposed too but what if. I will bet the stabilizer will be damaged but the frame will be worse off.
arpipeliner is offline   Reply With Quote
Old 12-02-2015, 07:23 PM   #13
AquaMan's Avatar
I don't think they clamp down tight enough to to do damage to the frame. They would break long before that would happen. The problem had to do with the cylinders themselves. Never really understood what the problem actually was with it, but I think it is listed on their website. I also know of a set that was installed by Lippert on a level up system in Goshen, so who knows.
Old 12-02-2015, 07:38 PM   #14
GLCM Warrior
Lefty59's Avatar
Here's what we use: BAL - Innovative Products for the RV Industry
It's lightweight, easy to set up and works real well for us. I typically leave the nose of our rig a pinch high until I have the tripod in place & then bump down the landing gear 2-3 times to firm it up. We then go set the rear stabilizers after that.
We might have installed another system, but would have had to relocate the spare tire as it is between the front legs of the landing gear. We tried this tripod instead & so far we're satisfied...even though we still do get some shake...we can live with it.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 12-02-2015, 10:44 PM   #15
I bought a tripod first. It helped some. Put on JT Strongarms and now don't use the tripod.
Jeff in NC is offline   Reply With Quote
5th wheel, wheel
