Old 11-30-2015, 10:20 PM   #1
Recommendation of a tripod stabilizer for 5th wheel
The long winter months of dreaming of camping has begun! With that trying to find a solution for the shake (side to side).
kmcook is offline   Reply With Quote
Old 11-30-2015, 10:24 PM   #2
TURBS's Avatar
Jt strongarms hands down.
Tripod is bulky , heavy , and you have to store it.
You won't be disappointed with jt's
Old 12-01-2015, 09:21 AM   #3
arpipeliner's Avatar
I agree. Gave the tripod away after the JTs installed.
arpipeliner is offline   Reply With Quote
Old 12-01-2015, 09:24 AM   #4
BamaBob's Avatar
X3 Forget the Tripod and install JT's
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 12-01-2015, 09:52 AM   #5
AquaMan's Avatar
I have a couple tripods I can sell you! I couldn't use the JT's because of having hydraulic landing gear, which required more modification than the bolt on system for electric. That said, it does take up a little storage room, but they do work. I have a steel one and aluminum one that I no longer need.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 12-01-2015, 10:44 AM   #6
I use an aluminum tripod and it takes a lot of the 'shake' out of the unit. The trick to the tripod is to set it up right and tight. The aluminum unit is so much lighter to handle than the steel unit and it provides the same level of support as the steel unit.
Gotta go campin!
Old 12-01-2015, 12:58 PM   #7
SlowrideHD's Avatar
I bought this one just to make the bedroom a little less shaky but I haven't used it yet.
Ultra-Fab Products 19-950001 Steel King Pin Tripod Stabilizer
I have a 6 point hydraulic Levelup system so most of the camper is solid.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 12-01-2015, 02:59 PM   #8
Jt strongarms for sure.
[SIGPIC]
2015 Palomino Columbus F375RL
2014 GMC Denali HD
6.6 turbo diesel 6-speed Allison transmission
jman63 is offline   Reply With Quote
Old 12-01-2015, 08:23 PM   #9
So, we two hydraulic round posts in the front with no holes. Can the JTs be installed?
Old 12-01-2015, 08:24 PM   #10
TURBS's Avatar
Yes.
Old 12-02-2015, 06:33 PM   #11
AquaMan's Avatar
Originally Posted by TURBS View Post
Yes.
And no. Lippert does not recommend installing them on hydraulic landing gear and have gone as far as saying your warranty may be voided, but they also sell the adapters to install them. Doesn't make much sense to me.
Old 12-02-2015, 08:14 PM   #12
CYA policy. Some people wouldn't understand that hydraulic shears are used to cut scrap steel. Imagine a locked stabilizer and hydraulic cyclinder vs LCI frame with a person not knowing when to stop.
Don't have auto level on my camper but could see a holy nightmare if you had it set up with stabilizers and accidentally the relevel button got pushed and it went thru a cycle. I hear it's not supposed too but what if. I will bet the stabilizer will be damaged but the frame will be worse off.
Old 12-02-2015, 08:23 PM   #13
AquaMan's Avatar
I don't think they clamp down tight enough to to do damage to the frame. They would break long before that would happen. The problem had to do with the cylinders themselves. Never really understood what the problem actually was with it, but I think it is listed on their website. I also know of a set that was installed by Lippert on a level up system in Goshen, so who knows.
Old 12-02-2015, 08:38 PM   #14
GLCM Warrior
Lefty59's Avatar
Here's what we use: BAL - Innovative Products for the RV Industry
It's lightweight, easy to set up and works real well for us. I typically leave the nose of our rig a pinch high until I have the tripod in place & then bump down the landing gear 2-3 times to firm it up. We then go set the rear stabilizers after that.
We might have installed another system, but would have had to relocate the spare tire as it is between the front legs of the landing gear. We tried this tripod instead & so far we're satisfied...even though we still do get some shake...we can live with it.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 12-02-2015, 11:44 PM   #15
I bought a tripod first. It helped some. Put on JT Strongarms and now don't use the tripod.
Jeff in NC is offline   Reply With Quote
5th wheel, wheel
