Red cable on Flagstaff 425D
Just purchased a used (2009) Flagstaff 425D. There is a red cable attached to the door side near the front of the unit that is loose on one end. I am assuming it is to prevent overextending everything when the top is cranked up. (battery lift) Does anyone know to attach the top eyelet of this cable to the roof? There is hole near where the cable probably was attached, but no screw. The bottom is attached with a Phillips head alum. screw.
