Old 06-07-2011, 09:03 PM   #1
refrigerator
turned on fridge to #5 and freezer is cold but fridge is not. whats the solution?
frankie62298 is offline   Reply With Quote
Old 06-07-2011, 09:04 PM   #2
flyrotor's Avatar
Give it some time, may take up to 6+ hours to get cold
flyrotor is offline   Reply With Quote
Old 06-07-2011, 09:05 PM   #3
sherdep's Avatar
you might get a better response if you give more info to what make and model your fridge and the Trailer as well
and post in the right forum
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-07-2011, 09:14 PM   #4
[QUOTE=frankie62298;109601]turned on fridge to #5 and freezer is cold but fridge is not. it is a domatic fridge
.whats the solution?
Old 06-07-2011, 09:40 PM   #5
sherdep's Avatar
is it on shore power or propane?
How long has the fridge / freezer been on for?
do you have a thermometer to verify the freezer is cold enough to keep it frozen and what temp is the fridge at?
Old 06-07-2011, 10:00 PM   #6
the freezer is very cold but fridge is about 60 degrees its been on for at least 7 hrs. it was on propane but turned over to electric a couple of hrs. ago
Old 06-07-2011, 10:09 PM   #7
jimh's Avatar
are u level?
i would think it should have started cooling in the frig by now. is the aluminum heat sink cold in the frig compartment?
jimh is offline   Reply With Quote
Old 06-07-2011, 10:12 PM   #8
Herk7769's Avatar
The "number 5" threw me. My temp controler is a clip that slides up and down one of the fins on the heat sink. I have no idea what make or model he has.
HAM CALLSIGN - KC3FFW
Old 06-07-2011, 11:12 PM   #9
jimh's Avatar
my 84 had a dometic and it had a dial. the switch over, from gas to elec, was mechanical and done from knobs on the front and bottom.
that unit use to take over night before the frig would get cold. abt 4 yrs after i had it (abt 1996), all u could hear was a girgle. when i tore into it, the steel tubing had rusted thru (in the cold section) and the ammonia had leaked out. what was surprising is that i never smelled it. the way the frig is installed, it is sealed off from the living area. guess it all went out the back.
Old 06-08-2011, 12:48 PM   #10
frankie62298, there is a refrigerator damper switch at the top f the door on some Dometic models that allows more or less cool air into the refrigerator area, depending on the switch's position. Open the fridge door, and look at the area between the fridge and freezer for the sliding switch. Not sure if all models have it or not, though. Good luck, Randy
