Old 05-03-2016, 10:24 AM   #1
Refrigerator only working when plugged into electric.
Does anyone have an idea of what to check?
My fridge only works if on electric mode. If I put on gas only the check light will come on.
Of course the gas is open.
Chevy Silverado 2500HD Duramax
Wildcat by Forest River
2 Kids and a Wife
andrea66 is offline   Reply With Quote
Old 05-03-2016, 10:27 AM   #2
Pickin' & Campin'
Do you hear any clicking (attempting to light) when on gas?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-03-2016, 10:29 AM   #3
Since it is spring, did you bleed the gas line by lighting the stove first? Often there is air in the line and it takes a while before the reefer gets any propane. Lighting the stove clears most of the air out. The check light is saying that it tried to light but didn't after a couple of tries.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-03-2016, 10:53 AM   #4
yetavon's Avatar
X2
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-03-2016, 11:52 AM   #5
Originally Posted by yetavon View Post
X2
I agree, sounds like air in the propane line. Light your stove and let it run for 5 minutes or so to get all the air out. If that doesn't work light your hot water heater. That should be the end of the line.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 05-03-2016, 11:56 AM   #6
Refrigerator only works on electric
yup, had the same problem with ours.....the fix was blowing out the fuel orifice. All it takes is a very fine insect nest to clog the nozzle
Just the 2 of us is offline   Reply With Quote
Old 05-03-2016, 03:17 PM   #7
Fridge & gas
Read instruction I over looked where it talked about a small off on screw for gas line
Louisiana Irishman is offline   Reply With Quote
Old 05-03-2016, 03:31 PM   #8
Pickin' & Campin'
Glad you found it and thanks for reporting back.
EDIT: Oops... thought that was the OP reporting back.
Sorry for the confusion.
Old 05-03-2016, 06:16 PM   #9
I had this problem with the trailer I had previous to this one and found all kinds of shavings in the line that blocked the orifice. Had to take it all apart and blow it out with air. Never failed again.
Stovebolt is offline   Reply With Quote
Old 05-03-2016, 09:00 PM   #10
Could Also be Your Igniter
We had that problem. We would hear the clicking but still no chilling. Found out that the igniter was bad and had to be replaced.
Reb Kitt is offline   Reply With Quote
electric, refrigerator
