Old 08-29-2016, 06:37 AM   #11
DouglasReid's Avatar
rather than drilling 3/8" holes I would consider getting some Joist Hangers from your local lumber yard or Lows, Home Depot, etc. You can afix them to the frame with only self tapping screws. They are designed to carry the weight and you do not risk weakening your frame by drilling holes.
If you MUST drill holes, Id use 1/4" instead and be sure to drill in the center of the frame member so as not to weaken it in either tension of compression when it flexes under a load.
Good Luck
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 08-29-2016, 07:02 AM   #12
Flybob's Avatar
A good welding shop can use carbon fiber protective cloth to protect the water barrier and tack weld 1.5- 2 inch "L" stock across there with no problem. A 2X4 can possibly warp and cause new problems.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
frame
