Old 10-01-2009, 01:13 PM   #1
Relatively new to Motor Homes
We have a basic toolbox (hammer, screwdriver,etc.)
What are the first things we should consider buying for the RV?
We are picking up the goergetown 378 this weekend.
Thanks!
landofdixie is offline   Reply With Quote
Old 10-01-2009, 02:20 PM   #2
Terry
First thing is a medical kit, always doing stupid things when you are away. Extra line for tank dumping incase they break. Good tire blocks just in case you get into a fix on the road. And most of all don't forget the duck tape, it is a life saver.
tlsheetz is offline   Reply With Quote
Old 10-01-2009, 05:03 PM   #3
If you have a spare, make sure you have a jack, and a lug wrench that will loosen the lugs. Power cord extension, sewer extension, water hose extension. Hook it up in the driveway and try everything 3 times or more. Get familiar with it. Read manuals, and carry them with you if you can, at least for a while. Plenty of food, beverage of choice, significant other, and just relax. Take time to enjoy, even when things don't go as planned, or something happens such as a tire problem. It's all part of life. Enjoy it.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 10-01-2009, 10:10 PM   #4
NWJeeper's Avatar
As the Georgetowns only have room for a spare tire and not a tire on a rim having a lug wrench is useless. Normally this would be good advice but you are stuck with calling out a mobile truck to remove a flat and change the tires for you. They should provide a little wrench for removing the decorative hub caps but by no means should you try and remove a lug with this. In fact, FR doesn't even provide a lug wrench for the above mentioned reason. I would recommend a good roadside service plan like Good Sam ERS. Same with a jack. Don't need one. The hydraulic levelers will lift the rig high enough to remove a tire but again, since you will have to call out a mobile truck to change a flat they have jacks with them. A good basic tool kit as well as spare fuses and bulbs for your lights both interior and exterior is a good thing to have though. Get a divided storage box and put in all kinds of fuses, bulbs, electrical tape, heat shrink tubing, etc, etc.
Ed & Wendy
www.nwjeepn.com
Old 10-02-2009, 10:03 AM   #5
thanks all.
Old 10-02-2009, 11:18 AM   #6
jaxfl's Avatar
For a class A the size you have the best tool in the tool box....Road side assistance, your choice of provider.
jaxfl is offline   Reply With Quote
