Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > General Tech and Repair
Old 01-06-2012, 12:24 PM   #1
Repairing our Suburban SF-30 - the Agony w/o the Ecstasy
Our 05 Wildwood came with an under-the-range mounted Suburban SF-30 propane furnace, which worked fine when we bought our trailer second hand in early 2008 -and has worked fine since until recently. Lately, it has either been hard to get started (taking several tries to get the burner to ignite), or like now, won't start at all and fails after 3 tries to ignite (our SF-30 has a 3 try controller). So, with cold temps and no heat at all, I set about learning all I could about this unit, in an effort to try to fix it myself if possible.
Part of the reason I went DIY on this is the local dealer wants $100 just to bench test the unit, and NO ONE wants to do remote service anymore.
So, armed with my vast troubleshooting knowledge and electronics background, I started off to do the deed myself. First, I downloaded every manual on the Suburban furnaces (and in particular the SF-30) that I could get my hands on, and poured over them. I tried every test I could WITHOUT removing the unit, but in my case, the sail switch and limit switch is working, and the unit is TRYING to fire off, but fails after 3 tries and locks out, which narrows down the number of things that can actually be wrong with it.
One test that is not documented anywhere is this one which I came to on my own: you can check to see if the gas valve is operational by putting the unit in heat mode and standing outside by the exhaust port while it tries to ignite. You will hear the unit attempt to fire off 3 times (the ignitor tries to spark several times during each round), and you can SMELL propane in the exhaust when the ignition fails if the gas valve is opening. This helps to rule out the limit switch, the sail switch, the gas valve, etc, but not the controller board or the ignitor, or a dirty combustion chamber.
The Suburban manuals makes removal and cleaning of the SF-30 SOUND EASY. IT IS NOT! In fact, given the shoddy install job done by Forest River installers at the factory, it is made harder than it should be.
FOR EXAMPLE, there is NO GAS SHUTOFF VALVE at the furnace. So, you have to shut off the gas at the tank, with the stove top burner going to burn off the excess propane in the line, BEFORE you disconnect the propane fitting. You also have to disconnect BOTH electric and battery power and work by flashlight to reduce the risk of spark/explosion.
The whole furnace unit is suspended in the cabinet frame with only two cabinet screws holding it in place (incredible!) and sits on top of two small blocks of wood, loosely attached to the floor, with a small piece of duct insulation filling in the gap. The whole furnace just sits in there loose. I was pretty stunned at the extremely poor quality of the installation of this vital piece of gear when I saw it!
Worse, FR provides no outside access door either (although FR could spend a few bucks extra and purchase the SF-30F model and install a door if they wanted to do a QUALITY job!) So, there is ZERO access to the on/off switch on the rear of the unit, or to the controller board, or to the blower motor, etc., without removing the ENTIRE furnace.
Also, FR did not install a plug connector for the 4 wires feeding the unit, nor is there enough slack in the wires, and since I am not a midget and I could not reach the factory wire nuts, I had to cut the wires, even though I would have PREFERRED NOT TO do so. A 4 wire connector plug would cost $2 maybe? Why FR opts to install this furnace without one is a mystery to me, but tells me that THERE ARE NO QUALITY AUDITORS WORKING AT THE FR FACTORY... none of this would pass a decent quality audit - I know I am a quality auditor.
The Suburban instructions tell you that the combustion chamber of their furnace needs to be cleaned every year. They do not tell you how TRULY DIFFICULT it is to do this. To get to the combustion chamber, doing it the way they describe, not only do you have to REMOVE THE ENTIRE FURNACE, (which means removing the exterior vent caps and gasket first and its 6 screws), then you have to remove the furnace from its housing (4 screws), remove the blower motor impeller assembly (many many screws), remove the blower motor itself, unscrew the connector to the ignitor at the gas valve, then remove the ignitor assembly and gasket from the combustion chamber (another 9 screws and a nut have to come off just for that step alone), which means dislodging the glob of firewall putty that is factory installed, too. Then you go rent or borrow an air compressor to clean out the labyrinthic combustion chamber. DOES THIS SOUND LIKE SOMETHING YOU WANT TO TO ANNUALLY???
Fortunately, there is an easier way - you can just remove the exterior vent cap and attach the hose from a 12 amp household vacuum cleaner to the exhaust port (it is a perfect fit by the way), and hold your hand over the INTAKE port and every spec of dirt in the combustion chamber will come out, WITHOUT REMOVING THE UNIT, or risking damage to it by completely dissembling it.
In my case, about a 1/2 tablespoon of very fine soot/sand (we live in Florida) came out of the chamber, which is not bad, considering that the furnace was like brand new when we bought it and we have used it maybe 10-15 times over a 4 year period.
Finally, I have learned from a Suburban authorized repair center rep, that given my symptoms, the odds are that my control board has gone bad and is not putting out enough spark. He told me that 9 out of 10 times this is the cause when it will try to ignite 3 times, but not fire off. He says the neon device on the OEM board goes bad often, for whatever reason.
The good folks at Dinosaur Electronics agree. They make an aftermarket control board for this unit called the FAN 50 PLUS PINS, which is a superior replacement to the POS Suburban board.
Given that I can buy the higher quality Dinosaur board for about $100 online, and the OEM board is $139, this is a real no brainer... I can get a better board and install it myself for the cost of putting my furnace on the bench at the local shop.
In conclusion, I think the whole problem here is that Suburban is making a furnace with substandard parts that is being installed in a substandard manner by Forest River, so that it lasts about 3-4 years if you are lucky, and then you have to start removing it and troubleshooting it to fix it. Because of the poor quality install job and the lack of an access panel, troubleshooting it 10 times more difficult than it has to be - and you are put at the mercy of the local dealer to repair the unit yourself. Most of this would not be necessary if both Suburban and Forest River would spend an extra $10 on the furnace and the installation of same. For starters, a gas shutoff valve at the unit seems like a basic safety item. Also, I don't see how this furnace could meet UL standards AFTER the installation if the ON/OFF switch is buried at the back of the unit!!! Lastly, the aforementioned four pin connector seems a must-have given that the furnace needs to be serviced now and then. Either that or just put in an access door! Seriously!
Since I know that a new SF-30 furnace costs about $595, it really makes you wonder where you reach the point of diminishing returns of one's efforts at repairing any furnace like this one. We're having family budget issues like most folks, so I don't have the luxury of buying a new replacementfurnace, or I would... because it would be 100 times easier to just drop a new SF-30 in the cabinet than to go thru this process again. And, if I had taken it into a local shop after removing it myself, the minimum repair bill for replacing a controller board would be about $300. Argh!
Hope this info helps others. At least the vacuum cleaner trick should.
walk_the_walk is offline   Reply With Quote
» Online Users: 671
146 members and 525 guests
11XLITE28BH, 4bnabird, 64c10, alphadog99, alpinemike, autorot8, BigKidzFun, Bigmatt, BigR, Bingo71, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Capsfloyd, carsonizik3, Cascade Bob, cdbus, ChrisZazzara, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, Dakota EV, dapersico, dashonthedash, davidjb, daw592, depo, Derekcan, djorgensen3, dnaraG_1M, doc73, donh, donn, doosterhouse, drobert, DTingle, EL99jl, emljr, Emptypockets, extremebike, Falcon35, feerobk, Fire Instructor, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, grhodes50, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itat, itech, Itsthetwoofus, Janet H, jar3316, JedinWI, jerrygallion, jjm901, jkinger, jmswms, jobren4, Juan.Cortes, ken0042, Kevin-and-Julie, KKapa, KoolAide, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, LuckyMcBRIDE, mbfree66, mhartzel, Michigan, Mickey1, mike2tall, mike54, Mrgary, NanaKaren, NINA, Nursx2, pgordemer, pg_rider, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, rbrandon, Redheaded blue tick, Retired63, rgmiller32, rick51, rickthelen, RJHuser, rob2112, Sahgie, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, sphinx, T.Kott, Tee, Test Account, thom01, tmmar, trailraider, travyp, Triguy, trudinator, True Believer, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, washdweller, wellcoman, whj77372, Wildcat Chris, wnytaxman, y01lxb
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
