Old 08-05-2016, 03:08 PM   #11
AMG
Originally Posted by Bama Rambler View Post
Here's one that's close to being the right size. I'll measure ours this evening and see if it'll fit.
I think this is a winner.
The holes cut in the ceiling are not precise and even the ones that come with my toy hauler do not fit super tight (they dont need to), but the screws hold them in. They look to be this exact same size.
It's funny how close I came. I looked at my order , it is a D&W 8840WH. I need an 8850!
https://www.amazon.com/8840WH-Spacep...ords=8850+vent
I believe I need 6 for my TH, but I ordered 7.
Also, FYI that it looks like the 2017 models have different registers (google image search), but I think I saw that brand and it didnt have adjustable louvers either.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 08-05-2016, 04:25 PM   #12
Head Rambler
Hopefully these will work. I'm going to order a few and if they work as well as I think, I'll change them all. I'm even thinking of adding one to the bedroom. There's plenty of duct after the one that's in there.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-05-2016, 10:39 PM   #13
In my unit you can hang meat in the bathroom when the a/c is on. I just pulled the vent out of the ceiling and made a round cardboard disk to cover the louvers and popped it back in. Now the bathroom is fine and I get more air flow to the one vent in our bedroom. Cardboard is your friend!
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 08-06-2016, 01:07 PM   #14
Head Rambler
I was going to block part of the vent if I couldn't find registers that would close.
I measured the registers in our RV and the D&W Jetstream 8850 are a perfect fit.
The O.D. of the registers in our RV are 6-7/8" and the hole size is 5-3/4".
The dimensions shown on the website for the 8850 are 6-7/8" O.D. and 5-13/16" Insertion size.
I ordered several, and I'll let everyone know how they turn out.
Gotta go campin!
Old 08-12-2016, 10:43 PM   #15
AMG
Got them. Pop them in tomorrow. Looks just like the ones that r there. Maybe the holes line up exactly too. We shall see
ID:	117064   Click image for larger version
Old 08-13-2016, 01:22 PM   #16
You may check with FR because my Georgetown has the adj register as oem.
2016 Georgetown 328ts
2015 Fiat 500 Toad
db7512 is offline   Reply With Quote
Old 08-13-2016, 09:35 PM   #17
Head Rambler
I installed the ones I ordered and they fit right in the existing mounting rings.
The airflow out of them seems to be greater, but that may be just because all the air is flowing the same direction.
Gotta go campin!
Old 08-14-2016, 09:14 PM   #18
AMG
100% identical back mounting ring. No need to even swap that (unscrew it). Simply use your finger, pull the current non-adjustable louver unit out, snap in the adjustable one. Done.
ID:	117294   Click image for larger version
ID:	117295   Click image for larger version
ID:	117296   Click image for larger version
Old 08-19-2016, 11:00 PM   #19
Having same issue
Top bunk is too cold for my son because the vent blows directly down on him. Bad design. I definitely need to find a way to control/close the air flow near that bunk. I almost bought the same small one on Amazon... Thanks for the post and info!
adr4 is offline   Reply With Quote
replacement
