Old 08-04-2016, 04:00 PM   #1
AMG
Replacement Adjustable A/C Register?
Anyone know of a manufacturer that makes a replacement A/C register that has adjustable louvers would fit the hole that FR cut in the ceilings?
I bought this one without measuring well, figuring if I buy *1* and it's wrong, so what. And it was, it doesn't fit.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 08-04-2016, 04:19 PM   #2
Head Rambler
What size hole is in the ceiling?
Have you looked at J&R products?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-04-2016, 04:51 PM   #3
AMG
I think 7"
I did check their site, none of them are large enough. It'd be nice if I could find out who made the ones that FR uses, as I could get exact specs and perhaps the mfgr has other models, but the same size.
ID:	116311   Click image for larger version
ID:	116312   Click image for larger version
Old 08-05-2016, 09:22 AM   #4
Head Rambler
Thanks for the pics and the info.
I was just looking at the same thing. The bathroom is always freezing in our RV and I am wanting to get some adjustable registers so I could close off the flow to the bath.
I guess we'll have to continue the search. I'll post if I find some that will work and would appreciate it if you would do the same.
Gotta go campin!
Old 08-05-2016, 09:37 AM   #5
Head Rambler
Here's one that's close to being the right size. I'll measure ours this evening and see if it'll fit.
Gotta go campin!
Old 08-05-2016, 09:41 AM   #6
There are some 7" ones listed **HERE.**
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-05-2016, 10:46 AM   #7
AMG
I'm going to go back to my toy hauler at lunch and measure a couple of the openings just to know exact sizing. More to come.
Also, not sure how that one installs, I dont see screw holes. Maybe it is similar to the stock ones where you pull out the louvers (non adjustable) and there are screw holes under. Let's deal with the size thing first.
Old 08-05-2016, 10:54 AM   #8
waiter21's Avatar
I used that louver when I modified my AC ceiling vent.
Here's a link, scroll down about half way.
Beat the heat – Improving air flow from the air conditioner ceiling unit | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-05-2016, 01:22 PM   #9
AMG
Beat the heat Improving air flow from the air conditioner ceiling unit | 2001 Coachmen Mirada 300QB
That's neat that it worked for you, but it is not relevant in this case as we have ducted installations of which the louver that you and I both bought, will not fit.
Thanks for the attempt to help though.
Old 08-05-2016, 01:42 PM   #10
waiter21's Avatar
You might try google images. Thats how I found this one..
replacement
