Old 06-27-2016, 07:08 AM   #1
Replacement for shear bolt on P30001 Powerwinch lift system
I was raising the roof on our 2007 Flagstaff popup and the bolt that the cable spools around sheared off the P300001 Powerwinch and the roof came crashing down.
I have called the manufacturer, and a company that sells that winch and neither carry that bolt, because the winch has been discontinued.
The motor runs fine so I would hate to have to replace the whole winch just because I can't locate the bolt.
It would be greatly appreciated if someone would be able to point me in the right directly.
bbirk1212 is offline   Reply With Quote
Old 06-27-2016, 07:24 AM   #2
Ford Idaho's Avatar
Fastenal is who I would try.
Old 06-27-2016, 07:26 AM   #3
dieselguy's Avatar
If you have both halves ... go to ACE Hardware, Lowes, or Home Depot ... they all carry assortments of fastners.
dieselguy is offline   Reply With Quote
Old 06-27-2016, 07:45 AM   #4
Thank you. I didn't know if this bolt is specific to this winch. I will take it to Ace and let you know what I find out.
Old 06-28-2016, 06:45 AM   #5
I went to Ace, Fastenal, and Home Depot and didn't receive much assistance. I have asked a local trailer company to ask their suppliers for help. Camping World also said that I would most likely have to replace the entire winch because this equipment is no longer available.
I have attached a couple of pictures of the part I am trying to replace.
It looks like I should be able to drill out the part of the bolt that shear off in the pinion. I am thinking of either trying that or finding someone to weld the part back on.
ID:	112452   Click image for larger version
Old 06-28-2016, 07:21 AM   #6
Is that item 21 on the link below? If so, that is not a shear bolt.
https://www.e-carefree.com/documenta...h%20Manual.pdf
Carefree is the company that sold these. Have you contacted their support folks?
RV Products - Carefree of Colorado
Maybe that same shaft is used in another of the Powerwinch products and you can still purchase it. Good luck!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
Old 06-28-2016, 07:23 AM   #7
Ford Idaho's Avatar
The center part could be a steel bar of the same diameter with a hole drilled thru the center the same size as the two threaded ends.
Any machine shop could make that then all you need is a grade 8 bolt to go thru to hold it all together.
Old 06-28-2016, 07:37 AM   #8
I did reach out to carefree and they said this winch is discontinued and they no longer care any parts for it. Thanks for the manual. The part is item 6 the cable shaft part number P9107400AJ. That helps a lot!
It does look like something a machine shop would be able to make as well. That was going to be my last resort.
Thanks for all of the help!
Old 06-28-2016, 07:50 AM   #9
You're welcome. I remember I had a boat trailer Powerwinch that had a defective brake. It sat in my attic forever and I trashed it 2 years ago when we went full timing. Makes me wonder if it had the same shaft in it.
Anyway, hope it doesn't cost too much to have one built. Here's a thought...sometimes local high schools and Tech schools will make things like that for the cost of materials. Back when I worked maintenance in a paper bag factory, we would make things like that, for ourselves and friends, at night when the bosses weren't around!
Old 06-28-2016, 07:56 AM   #10
It would be good practice for an apprentice.
I could get lucky and find someone that has the same winch with a bad motor. Our next trip wont be until end of July so I still have a couple of weeks to search.
power, replacement
