Old 02-18-2015, 12:19 PM   #1
Unhappy Replacement keys?
So our 2011 Salem 36BHBS camper was a repo and only came with one key, This key locked/unlocked the doors as well as the compartments. I was going around emptying the compartments and broke the key... super. The numbers on the key are 1681 F1C3 but I was told these are just for the blanks? There is no code stamped on any of the locks. What's the best way to get this situation taken care of?
bab5871 is offline   Reply With Quote
Old 02-18-2015, 12:22 PM   #2
fonzie's Avatar
Amazon.com: FIC3 1681 RV Key Blank: Home Improvement
If you still have both pieces, bring to a locksmith so he can cut a new one hopefully...
Fonzie
Old 02-18-2015, 12:25 PM   #3
geotex1's Avatar
Roll into any camper dealership with a parts/service department. They'll have precut keys right on the rack. There's only a finite number of the double sided keys (that blank is a double sider) that fit the common trailer locks and compartments so you may need to buy a few and return what doesn't fit. Most of the double-sided key lock cylinders don't have the code on them like the old CH-keys.
geotex1 is offline   Reply With Quote
Old 02-18-2015, 12:38 PM   #4
Unfortunately the other piece is stuck in one of the locks still...
Old 02-18-2015, 12:43 PM   #5
I called around to the dealerships in the area here, none have pre-cut keys. They said there should be a number on the key, which is the blank number, and they can cut a key from that. So I guess it looks like I'm going to be replacing my locks unfortunately.
Old 02-18-2015, 12:54 PM   #6
caper's Avatar
Call your local lock smith and tell him the situation. He/she might be able to help and not have to purchase all new locks. If they can retrieve the broken half it would not be hard to make a copy for you. Lock smiths have ways to measure cut depths and machines that can cut locks with out using existing keys.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-18-2015, 02:48 PM   #7
geotex1's Avatar
x2. A pair of precision-work needle-nose pliers might be able to retrieve it too.
Hard to believe they don't have cut keys!!! My local dealer, who I loathe but has a nice parts stock, has a rack that sits right on the parts counter with about 18 standard keys.
You *might* be able to call FR with your VIN# and find out what locks they were using at the time too.
Hope you sort it soon!
Old 02-18-2015, 03:21 PM   #8
Mojojojo's Avatar
Take a lock off one compartment and take it to a local lock smith he can cut a key
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-18-2015, 03:36 PM   #9
Brother Les's Avatar
Is the compartment open that you broke the key off in. Take the lock off and take it to a locksmith. He can get the key out and make a new one for you.
Brother Les
Old 02-18-2015, 07:16 PM   #10
If that is the old HF series you can buy all available key codes for $56. Same for the newer CW series. Then resell all the keys you don't need for $1 each on ebay...
First link below is for HF, 2nd one is for CW:
Products
Products
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
replacement
