Originally Posted by rockwood06
Really! be for I had them installed I check with the shop I deal with for the last 30 years or so and they said there is no problem using the same rims. I have a new Chevy truck that came with "C" rated tires @ 35psi and the chevy dealer suggested to change them to "E" rated tires @ 80psi for towing, so I ask can I use the same rims and they said yes, there would be no problem and I have a 6 lug wheel. I am going to have to check with them again before I change them.
I thought the same but on another forum I read about the wheel rating. I found my rating stamped on the inside of the wheel. A 50psi wheel will only support a load range C tire. A D tire requires a 65psi wheel and an E rated an 80psi wheel.
There is a very good chance that the Chevy wheel can handle an 80psi tire. It would make sense to stock one wheel that would cover both the 1500 and 2500 series trucks. Also from what I have seen looking at wheels most 6 lug wheels are 65 or 80 psi rated. They are also usally 16inch wheels. My old 1500 and my 2500 were both 6 lug 16 inch wheels.
2006 2500HD Chevy 6.0 Gas Ext Cab Short Bed
2004 Flagstaff 8528BHSS 5th Wheel
Dear Wife, two daughters and four dogs
