Old 07-20-2016, 12:57 PM   #1
BlackJeep22's Avatar
RIde rite air pressure, recommendations?
All I can find on this us Minimum 5lbs. Maximum 100 lbs. I have a 2016 Coachman Concord 300DS.
Thanks in advance.
BlackJeep22 is offline   Reply With Quote
Old 07-20-2016, 03:05 PM   #2
grumpy0374's Avatar
Our Lexington 283ts is the same as your Concord, same air bag system.
Never run with them empty, keep a minimum of 10-15 psi. Max psi is 100.
You need to experimint with different psi settings until you find the most comfortable ride. Depending on your loaded out weight, and how much is on the rear end, I'd start at 50 psi, and go up or down in 5 psi incriments.
Be aware, the air bags themselves are small, and it does not take any time at all to hit 100 psi. When you add air just add it a "blip"...maybe a second or two at a time. It would probably take no more than 10-12 seconds to go from totally empty, to full 100 psi.
For info, I setteled on 60-65 psi on our Lexi. That psi along with the Bilsteins I installed, give me a firm but comfortable ride.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 07-20-2016, 03:22 PM   #3
I agree with grumpy. I've experimented, starting at 20 psi and going up in 5lb increments, and have settled on 35psi. A heavier FW would presumably require higher PSI.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 07-22-2016, 12:49 PM   #4
Spikedog's Avatar
I run about 10 psi
Get up to 35 psi and the ride is terrible, way too bouncy. Depends on how heavily loaded your rig is. Like previous posters stated, try out different pressures, but vary only by 5 psi at a time and start out low. You don't want them empty either - I think the minimum is 5 or 10 psi.
2007 Coachman Freelander 26' w/ E-450 6.0 diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
pressure
