Old 06-13-2011, 08:01 PM   #1
Rockwood 1640 ltd
Okay Fellas, we just took our Rockwood 1640 ltd camper out for the first time. Plugged it into 110, we had power to our plug-ins but none to the ceiling lights. Also the green light for the carbon monoxide was not on, which we were told should be on when we set the sink upright, as it sets a switch. Anybody have any suggestions? We finally just gave up this evening, came back home and will go back to the camper tomorrow and try to get it working. We just went 15 miles from home, luckily, so not very far to travel. Looking forward to your input. Probably will need to re-read the fridge operation also, but will look through the manual. I believe Rockwood should put out a better manual on thier campers. Thanks for all the anticipated help.
frank 1 is offline   Reply With Quote
Old 06-13-2011, 10:06 PM   #2
bikendan's Avatar
you haven't mentioned whether you have a 12v battery or not.
Old 06-13-2011, 10:49 PM   #3
Yes it has a 12 volt system and 110. I have power to the inside recepticals but no ceiling lights.
Old 06-13-2011, 11:01 PM   #4
buckisland1950's Avatar
Most ceiling lights are 12 volts. Check for a blown fuse or bad battery connection, the detector most likely works off of 12 volts also.
2011 F250 Lariat Crew Cab 6.7L Diesel
2011 Flagstaff Classic Superlite 831 FKBSS
Fleet of Canoes and one Kayak
So Many Rivers so Little Time!
buckisland1950 is offline   Reply With Quote
Old 06-13-2011, 11:08 PM   #5
bikendan's Avatar
i know it has a 12v system, i'm asking if you have a battery hooked up.
the lights and CO2 run on 12v power and your popup may need a battery in order to run, even if you're plugged into shore power.
Old 06-14-2011, 10:16 AM   #6
Yes, I have a battery hooked up.
Old 06-15-2011, 10:20 AM   #7
bikendan's Avatar
then the battery needs to be tested first.
not sure how the converter works on the popup. it may not be recharging the battery, if the battery is good.
or if the battery is good, it may have been hooked up backwards and tripped the inline breaker.
Old 06-23-2011, 10:39 AM   #8
PKRZRL's Avatar
I have a Rockwood 1940 LTD - the first thing I'd do is flip the sink over and check the wires that connect to the "red button" safety under the sink. Sometimes those wires come loose when you flip up the sink. If those wires aren't connected, the lights and CO detector won't operate.
PKRZRL is offline   Reply With Quote
