Old 06-22-2011, 04:55 PM   #1
rodupr's Avatar
Rockwood 8281ss shower leaking
Has anyone else with this camper had a problem with the shower leaking? I have caulked every crack I can find and there is still some water leaking. It seems to be coming from the back corner where the toilet is. If I take a shower in there the plywood gets wet near the outside wall in the basement. It's not a heavy leak but enough to see and feel underneath on the floor.
Just wondering if anyone else has seen this?
2011 F-250 CC 6.2L 4x4
2011 Rockwood 8281SS
rodupr is offline   Reply With Quote
Old 06-22-2011, 06:17 PM   #2
fivecodys's Avatar
Is it leaking around the aluminum glass frames or is this from underneath?
We had a problem with water coming around the door and glass panel frames in our neo-shower.
I bought good quality clear caulking and went over every inside corner and even over the rubber spline between the glass and the frames.
This was done on the inside of the shower not the exterior.
This seems to have solved the problem.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 06-22-2011, 06:29 PM   #3
rodupr's Avatar
It is showing up underneath the shower. I can't tell exactly where it's coming from.
I have already done exactly what you said. I have caulked everything on the inside.
I wonder if there is a pin hole in the pan somewhere?
I am baffled.
Old 01-02-2014, 12:05 PM   #4
bluebeast's Avatar
Have you found a fix? Mine is doing the same thing.
bluebeast is offline   Reply With Quote
