Old 08-06-2008, 11:02 PM   #1
Rockwood Model 1980 Frig question
I recently purchased a 2003 Rockwood Freedom Model 1980 from a person that I know. He told me that the refrigerator has never worked properly and he discontinued using it. He stated that a recall was issued for this unit. How can I get info on this recall? how has others handled this problem.
banjo is offline   Reply With Quote
Old 08-07-2008, 07:15 AM   #2
Head Rambler
We really need to know more about the fridge. Make, model, etc. That info can usually be found on the door. We also need to know exactly what's not working about it. Does it work on electric. Does it work on propane? Does it not get cold enough? We also need to know if you have a battery and is it charged?
Having said that since they stated it had a recall on it, it's most likely a Dometic. You can use the model and serial number and go to the Dometic website and enter that info and it'll tell you if your unit is part of the recall. Keep in mind that just because it's part of the recall it may not be why the unit isn't working so the recall may not help you.
Let us know any of the above requested info and we can certainly confuse you more if we can't do anything else.
Gotta go campin!
