Old 08-10-2010, 03:02 PM   #1
jerr7's Avatar
Send a message via AIM to jerr7
Cool roo23ss 2009 axles/grease question
I have the Roo 23SS HT i checked my booklet on the axles and wanted to find out what type i have.In the Al/Ko i assume i have a reg axle that uses reg grease for the fittings,What i want to know is these axles the EZ lube type ??? or reg type that i used when i had a popup.I see people had use this new type of be able to grease it .I beleive its a Buddy grease.Anyway if i have the dealer do it how do i know if they use the reg way to apply or these new ready made type. Is there a preference.
jerry
jerr7 is offline   Reply With Quote
Old 08-10-2010, 06:47 PM   #2
milzat's Avatar
If it's got a grease fitting on the end of the hub, behind a rubber plug, you can lube it yourself. The excess grease will ooz back into the cap.
milzat is offline   Reply With Quote
Old 08-11-2010, 08:05 AM   #3
MtnGuy's Avatar
To add to Mike's advice.
Make sure you buy grease that meets the manufacturers criteria.
Get the tire off of the ground and spin in while using the EZ Lube hub. That should help keep any grease within the hub and not be forced into the brake drum area.
Don' overfill. When you get new grease coming out from around the outside bearings, stop there. Wipe some of old grease out. Be careful, as the grease cap can have a sharp edge.
Never used an air-powered grease gun !!
Old 08-11-2010, 10:33 AM   #4
Here's what a Bearing Buddy looks like. They have a grey vinyl cap or "bra" (as they call it) that slips over the end of the part. The BB is chrome plated & pressed into the axle end.
Finally, when you take the "cap" off, you'll notice a spring inside around the "bore" pushing against the piston.
Genuine Bearing Buddy Web Site
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-11-2010, 11:35 AM   #5
jerr7's Avatar
Thanks mike and all you guys now i know ill do what i been for years repack myself .lol do they sell a kit for new seals and such. Again thanks for the help
jerry.
23ss, axle
