Old 09-16-2014, 02:55 AM   #1
Rubber gasket around Slide
Hey All, just looking for some advice. I am in the process of doing my total fall clean from top to bottom. The only thing I have left is on my rubber gasket that is between my slide out and camper.
(It used to be white)... It is almost black from mildew, I guess. I tried Awsome first because it seems to work on just about everything. Even that won't touch it. So I tried some bleach water and no luck. Anyone have any luck getting that junk off?
BradW is offline   Reply With Quote
Old 09-16-2014, 06:07 AM   #2
Alleged curmudgeon
Vern's Avatar
I don't know exactly what "gasket" you are talking about, as the only thing I can imagine is a slide out seal, which is black rubber on my TT. If you are referring to rubber slide out seals, I'd be reluctant to use harsh cleaners or chlorine on them, since you need the seals to remain supple. I wash mine with soapy water when I'm washing my TT, and use "slide out conditioner" (available from Camping World) a couple of times each season to attempt to condition and maintain the seal.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
Vern is offline   Reply With Quote
Old 09-23-2014, 09:53 PM   #3
deartruc's Avatar
I can't imagine white rubber. Unless it got chalky. I use silicon spray like you'd use on your cars door seals. Doesn't stay wet or attract dirt.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 09-28-2014, 06:21 AM   #4
Alleged curmudgeon
Vern's Avatar
BradW - Just occurred to me...you may be talking about the "gasket" or seal on the inside (hidden by the slide fascia)? That's one I've never even thought about cleaning or treating. There probably is something for that, although I'd be pretty concerned if it were showing mildew. Maybe someone else knows?
Lee
Old 09-28-2014, 06:35 AM   #5
mud yapster's Avatar
How about a pic so we can help better
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
gas, slide
