Old 05-03-2010, 04:32 PM   #11
EastlakeRoo's Avatar
I'll have to take a closer look at the slide and see if I can do the same thing by slipping the cord in before fully extended. I will have to take a closer look next time I'm by my trailer. Thanks for sharing.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 05-03-2010, 04:36 PM   #12
Grape Escape
I slipped an extention cord thru the bottom edge of slideout to run port heater when we had our 2607 which saved overloading 30 amp sytem in trailer
Very easy to slip it in past bottom seal and locate plug under jack sofa
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 05-04-2010, 03:45 PM   #13
fivecodys's Avatar
Yep! We do the same thing. It's easy and works well.
I do like the other idea of making a permanent connection.
Sure would like to see that drawing.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 05-06-2010, 11:02 AM   #14
sonicsix's Avatar
We did this on our camper. Very easy to do using common items found at Lowe's or any hardware store. Here is what ours looks like, outlet inside and plug in outside. We run a heavy cord to the pedestal from there.
sonicsix is offline   Reply With Quote
Old 05-06-2010, 12:38 PM   #15
Cyber Phrenologist
Radio's Avatar
I'm lazy. And cheap. One really cold night I just ran a heavy extension cord out through the slide out seal (poke it through while the slide is about half way out) and it worked great.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-06-2010, 03:15 PM   #16
fivecodys's Avatar
KU4OJ from N6OVZ....
What?........ A cheap AND lazy HAM?
Can't be true!
73's
Bill
N6OVZ
Air Lift 5000
Old 05-12-2010, 10:52 AM   #17
Update: I went the route that cardinal4fun went by sliding a heavy duty extension cord in the trailer before the slider was fully extended and that trick worked. Went camping this past weekend and temps were in the 40's at night and 50's during the day and our 1500 watt little heater kept the trailer in the 70's during the day and night. Didn't have to kick on the furnace one time the entire weekend. Just wanted to share the experience. Hopefully the weather will warm up soon in Northern Ohio so I don't have to worry about heat. cheers
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
