Old 05-03-2010, 07:43 AM   #1
EastlakeRoo's Avatar
Question Running Dedicated Outlet for Portable Heater
Have a 2010 2607 Ultra lite and was wondering if anyone has ever ran a dedicated outlet for a portable heater?? Reason I'm looking for a dedicated outlet is so that I can run the heater off the campground power versus running it off my internal electrical system. When I had my previous trailer I would trip a breaker when I had the heater going and coffee pot on. Has anyone ran into a similar issue or is there a alternative to the outlet method? Looking for a easy solution.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 05-03-2010, 07:58 AM   #2
tmmar's Avatar
Couldn't you just use a heavy duty extension cord plugged directly to the campground pedestal
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-03-2010, 08:39 AM   #3
I suppose I could do that but I wanted to run the extension cord in such a way that I don't have to leave a storage door or window open. I've heard of some guys having a dedicated outlet that is supplied somehow by a male plug somewhere outside the trailer. What they would do is get another extension cord plug it into the campground outlet and the other end to the male adapter supplying the outlet and all set. The only way I see this can be done is by cutting a hole in the trailer floor to run the line and before I go this route I wanted to see what other alternatives there are. Just hate to cut into anything as my trailer is brand new and hasn't been camped in yet. Let me know if there are any other ideas/suggestions. I appreciate the assistance.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 05-03-2010, 08:51 AM   #4
tmmar's Avatar
I wouldn't want to cut a hole in my motor home either (whether or not it had been camped in) especially one that is a month old. That is why I suggested the extension cord.
Tom and Margaret
Old 05-03-2010, 09:05 AM   #5
KyDan's Avatar
Been there, done that.
It's fairly easy DIY job if you are the least bit familiar around
an electrical panel.
Your and my trailer has one circuit for all outlets.
It's a 15 amp ground fault outlet.
Yet your trailer has a 30 amp "supply" input.
I bet your circuit box commonly referred to as the "power center"
has extra spaces for another circuit breaker.
These circuit breakers are common plug in breakers and can
be bought at Home Depot, Lowes or most any well stocked
hardware store.
I simply plugged in another 15 amp breaker and ran a short wire
from it over to the adjoining toe kick area under my sink.
I was able to install an "old work" plastic outlet box in the
toe kick. It took about 6 or 7 feet of 14-2 romex wire.
You can purchase cut lengths or just a 25 foot roll of that at the
above mentioned stores.
The entire job took me an hour but I admit I do have experience
in this area. (34 years as an industrial maintenance electrician/mechanic)
I can provide photo if you want one just ask.
Now we can perk coffee or toast bread AND run the electric heater
at the same time!
We've never kicked the 30 amp breaker on the camp ground post
nor the main breaker in our power center.
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-03-2010, 09:12 AM   #6
milzat's Avatar
This has been done before.
I posted a drawing awhile back, with pics. I'll have to search for it. When I find it, it'll post it for you to view.
milzat is offline   Reply With Quote
Old 05-03-2010, 10:06 AM   #7
Well, from an engineering point of view, all of this discussion is about a problem with the OLD trailer that is now gone. EASTLAKEROO, have you tried it with the NEW trailer to see what happens? (or am I missing something?) There is always a way to solve a problem, but no need to solve one till you're sure you have it. Kydan said he had the same trailer, only two years older, and may be true, but I've seen and read post on here where two identical trailers were not wired or plumbed the same. TEST it first. Just my two cents, your mileage may vary.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-03-2010, 10:08 AM   #8
milzat's Avatar
Youíll need one of these to plug your 20 amp rated extension cord, from the campground pedestal, to your trailer.
20A POWER INLET, (20A, 125V straight blade inlet. Use with any standard 20A extension cord).
Mount it inside one of your outside storage compartments.
Run ROMEX from the 20A inlet to where you will mount a 20A GFCI receptacle inside your trailer.
Install an electrical utility hatch on the compartment door. This way, you'll be cutting a hole in the compartment door, insted of your trailer sidewall.
Run the extension cord through the electrical hatch and plug it into the 20A inlet.
Old 05-03-2010, 01:23 PM   #9
Thanks everyone for all the suggestions. I'm going to see what I can install over the next few days so we have no issues running the heater and other accessories this upcoming weekend Also, this is for a 2010 Rockwood 2607 Ultra Lite as we moved up from our 2008 Rockwood Roo 21RS.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 05-03-2010, 01:27 PM   #10
cardinal4fun's Avatar
I was going to do the same thing at one time. I was going to get the male plug as showen in one of the post then a standard outlet inside the trailer. Use a heavy gauge extensen cord plugged into cg 110 plug. I gave that idea up and now just use the heavy duty extension cord. Before the slide is fully extended i slip the cord in and just go that way.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
