Old 10-30-2014, 08:46 PM   #1
Mark Burkholz's Avatar
Running lights
2109 mini lite. I have no running lights. Brake and signals work but nothing else. Any suggestions? TIA!
Mark Burkholz is offline   Reply With Quote
Old 10-30-2014, 08:59 PM   #2
check for good grounds
drc343 is online now   Reply With Quote
Old 10-30-2014, 09:07 PM   #3
I had the same problem. Someone suggested trying a different truck hook up. Different truck worked fine. Bad fuse in my truck. Controlled only the running lights.
2012 F250 6.2 gasser 373 rear
2013 Rockwood 2104S Mini Lite
Ole Buzzard is online now   Reply With Quote
Old 11-02-2014, 04:33 PM   #4
Toy-aholic
X2 on ^^^^^^^ my bet is fuse in your truck
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 11-02-2014, 05:28 PM   #5
Oaklevel's Avatar
X3
Some trucks have separate fuses for trailer lights. The truck will work fine but a trailer fuse could be blown. 2nd idea would be ground issues. Several of my trailers I run a separate ground between the trailer frame & the truck frame. Also a 12V tester would help trouble shoot greatly.
My bet would be an issue on the truck side. Good Luck !!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 11-02-2014, 07:52 PM   #6
Trailer fuse in truck was blown.Thanks for the suggestions@
light
