Old 08-24-2016, 08:24 PM   #1
RV Slide Issue and weather stripping melted
We had our first big trip and had a few issues - are any of these covered by the warranty? The RV is 9 months old.
1) the first issue was we went to close the Bedroom slide and it moved in about 2 inched then the right hand side got stuck, it was almost like it was not pulling the slide in evenly. The right side of the slide was getting caught and the left side was trying to come in. We made sure that nothing was blocking it and by the third attempt it released - on the third tried we held in the button for about 2-3 seconds and it finally caught and aligned itself then came in. Is there a way to move it manually, i was told there is but not sure what to look for
2) The second problem was the weather stripping on the outside kitchen came off (see attached pictured), it is if it melted.
3) The compartment on the RV where the water pump is below and to the right of the outside kitchen, has warped fiberglass and all the weather stripping came loose, melted and is no longer attached. I didnít look at it closely after we purchased the RV so I donít know if it was always warped and the Black filler covered the imperfection but there is a large GAP between the side of the compartment and the Fiber glass panel. Is this warranty or what should I get to repair it myself. Thanks the two photos on the top left and below it is outside kitchen and the other are the compartment where the water pump is
ID:	118367   Click image for larger version
ID:	118368   Click image for larger version
ID:	118369   Click image for larger version
ID:	118370   Click image for larger version
Steveanddianne is offline   Reply With Quote
Old 08-24-2016, 08:29 PM   #2
northstar1960's Avatar
you should have a year warranty . so call the dealer or fr and get the process started . you may get it done buy next spring
northstar1960 is offline   Reply With Quote
Old 08-28-2016, 02:12 PM   #3
Bill and Gail's Avatar
Hi,
If you have the Lippert Schwintek slides, there is a video on youtube that shows how to retime them, also some on overriding and manual closing. I had to retime mine when I bought my rig, it was off from them demonstrating it at the dealer. https://www.google.com/url?sa=t&sour...bdyQJ5VTbO9YEQ
Bill and Gail is offline   Reply With Quote
slide
