02-23-2011, 10:06 AM
RV Toilet Paper
Please explain to me, what is the difference between RV Toilet Paper, and what you buy at the local store? Other than price.
02-23-2011, 10:15 AM
The RV toilet paper is designed to leave your hand full of u know what. The TP at home isn't.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
02-23-2011, 10:20 AM
Regular single sheet TP should work fine in an RV toilet. Don't use fluffy TP like Charmin or Cottenelle, or there could be trouble lurking in your tank.
Scotts makes a single sheet paper.
02-23-2011, 10:24 AM
EXACTLY
We buy what's on sale or simply bring our favorite from home.
Others here will swear it matters and you should only use
RV because it won't clog your holding tank.
I disagree.
There is an alternative--- we don't flush the TP in the RV.
We toss it in a waste basket in the john. We use a walmart
bag as a can liner and typically take out the trash each
evening with the kitchen scraps while we're doing our
evening walk-about.
We're old house-boaters and marine toilets absolutely don't
want TP of any kind so we've been potty trained that way.
Don't stress out over this!!
Peace!
Dan & Rita D
02-23-2011, 11:14 AM
Not stressing out, just curious.
02-23-2011, 11:37 AM
Anyone use the Scott's RV TP? I found it at WalMart for under 3.00 for a 4pk.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
02-23-2011, 11:50 AM
I believe the rv paper has a lot less wet strength, therefore it breaks down easier in water. Wwith a good rinse of the holding tank after every empty, you should be fine no matter what goes down it.
I make toilet paper for a living and have not bought any in over 10 years, I use the same stuff in the trailer as in the house. I can tell you that certain ones have a lot of wet strength and take a long time to break down whether at home or in the rv.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
02-23-2011, 11:57 AM
if you are unsure if your home TP is safe for septic/holding tanks, then take one square of it and put into a glass of water and shake up the glass. if the TP falls apart then you have nothing to worry about. We use Quilted northern, it is safe to use and cost's less/feels better.
02-23-2011, 12:27 PM
I agree with Danielflading. The reason people are so worred about TP is because it needs to break down. It will be stuck in places within your tank if it does not break down correctly. For example it may get stuck to your tank sensors giving you false readings. The best thing is put the tp in a glass of water for how ever long you thing you will go without dumping. If it falls apart then it will be easier to keep tank free of extra TP. If it is still together then prepare for it to be stuck through out the black water tank and POSSIBLE issues in the future.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
02-23-2011, 12:34 PM
We have always bought RV TP when we had our hybrid. I have read lots of opinions on this. I believe it's how you clean out the black tank at the end of a trip that counts. Does anyone use the water softener trick to keep the tank "slick"?
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
02-23-2011, 12:36 PM
What is the trick and how do you get soft water?
02-23-2011, 12:46 PM
Using Calgon Water Softener in the black tank is supposed to keep the sides and probes slick so that solids will be easier to remove. I do that, and so far have not had a problem with my black tank.
02-23-2011, 12:48 PM
we have used Charmain for 2 yeas fulltime everthing is fine
02-23-2011, 12:50 PM
What about regular salt? Like for actual water softners? It may take awhile to break down but cheap.
02-23-2011, 12:53 PM
NO. The salt used for water softeners is only a catalyst for the regeneration process.....it is not the same.
02-23-2011, 12:58 PM
Use Scotts RV toilet paper, works great and breaks down fast in your holding tank and not on your hands! Scott® Bath Tissue Products | Bathroom Tissue Rolls
you can find it at Walmart
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
02-23-2011, 02:03 PM
I use RV DIGEST-IT and everything gets broken down, I do not use the Calgon.
RV DIGEST-IT, is worth every penny and I have been told it is the best product out there.
02-23-2011, 06:32 PM
This is an interesting read: RV Waste Water Treatment
The 2nd section is on the Geo method. Seems like the author of the website no longer uses the Geo method. I use the Calgon in my black tank, along with a deodorizer, but I do not use bleach in the tank. I would be a little leery of mixing bleach with other chemicals.
02-23-2011, 08:13 PM
Scoob, google Calgon Water Softener and you will get the formula. It is a chemical with very specific qualities that keep dirt from sticking to stuff; like clothes and black tanks. It is not salt.
As to RV Digester; I bought a quart and man does this work like a champ.
I still use Calgon and laundry soap; but after a month of dry camping I find the RV Digester is needed. I do the 24 hour soak and dump when we get into hookups.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Thanks.
As for a easily broken down home paper, angel soft would probably be the best bet.
I personally have never put anything but quilted northern in my trailer toilet and have no problems, and quilted northern is a lot harder to break down than rv paper or value paper.
