Old 02-23-2011, 09:06 AM   #1
RV Toilet Paper
Please explain to me, what is the difference between RV Toilet Paper, and what you buy at the local store? Other than price.
jcts43 is offline   Reply With Quote
Old 02-23-2011, 09:15 AM   #2
frankm's Avatar
The RV toilet paper is designed to leave your hand full of u know what. The TP at home isn't.
Frank & Rita M
2017 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 02-23-2011, 09:20 AM   #3
MtnGuy's Avatar
Regular single sheet TP should work fine in an RV toilet. Don't use fluffy TP like Charmin or Cottenelle, or there could be trouble lurking in your tank.
Scotts makes a single sheet paper.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
Old 02-23-2011, 09:24 AM   #4
KyDan's Avatar
EXACTLY
We buy what's on sale or simply bring our favorite from home.
Others here will swear it matters and you should only use
RV because it won't clog your holding tank.
I disagree.
There is an alternative--- we don't flush the TP in the RV.
We toss it in a waste basket in the john. We use a walmart
bag as a can liner and typically take out the trash each
evening with the kitchen scraps while we're doing our
evening walk-about.
We're old house-boaters and marine toilets absolutely don't
want TP of any kind so we've been potty trained that way.
Don't stress out over this!!
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-36
Old 02-23-2011, 10:14 AM   #5
Not stressing out, just curious.
Old 02-23-2011, 10:37 AM   #6
hockeytownmom's Avatar
Anyone use the Scott's RV TP? I found it at WalMart for under 3.00 for a 4pk.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 02-23-2011, 10:50 AM   #7
I believe the rv paper has a lot less wet strength, therefore it breaks down easier in water. Wwith a good rinse of the holding tank after every empty, you should be fine no matter what goes down it.
I make toilet paper for a living and have not bought any in over 10 years, I use the same stuff in the trailer as in the house. I can tell you that certain ones have a lot of wet strength and take a long time to break down whether at home or in the rv.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 02-23-2011, 10:57 AM   #8
BigDTx's Avatar
if you are unsure if your home TP is safe for septic/holding tanks, then take one square of it and put into a glass of water and shake up the glass. if the TP falls apart then you have nothing to worry about. We use Quilted northern, it is safe to use and cost's less/feels better.
BigDTx is offline   Reply With Quote
Old 02-23-2011, 11:27 AM   #9
Send a message via Skype™ to scubieman
I agree with Danielflading. The reason people are so worred about TP is because it needs to break down. It will be stuck in places within your tank if it does not break down correctly. For example it may get stuck to your tank sensors giving you false readings. The best thing is put the tp in a glass of water for how ever long you thing you will go without dumping. If it falls apart then it will be easier to keep tank free of extra TP. If it is still together then prepare for it to be stuck through out the black water tank and POSSIBLE issues in the future.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 02-23-2011, 11:34 AM   #10
Big Dawg's Avatar
We have always bought RV TP when we had our hybrid. I have read lots of opinions on this. I believe it's how you clean out the black tank at the end of a trip that counts. Does anyone use the water softener trick to keep the tank "slick"?
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
