Forest River Forums
Sunline User Photos
Old 01-07-2012, 09:48 PM   #1
Sandpiper Slide Problem
Purchased a Sandpiper 365SAQ. After 6 months of use, we started having slide problems. When you hold the button to open, the front, middle and one side goes out. The other rear slide will stop. Even the motor stops. You can let the button off and push it again and it will start moving then stop. This goes on several times. Same thing happens when you go in. Doesn't do it every time. Any ideas? Switch going bad?
gsm456 is offline   Reply With Quote
Old 01-08-2012, 04:40 AM   #2
Mountainmanbob's Avatar
amazing what a little grease and silicone can do
seen my friends slide out act up
the motors I think
stop easy on purpose
so as not to destroy something
just enough kick so as to
get the THING out there
many times these ones
straight from the factory
are NOT greased as one would think
and at times
workers get light with the grease
and then others such as my friend
let his slide on his older unit
get somewhat dry
he took it to an RV shop
for the so called pro lube
they did not do a good job
but
charged an arm and a leg
best to know it
and
do it yourself
try the very best you can
to get to all moving parts
and lube everyTHING up well
it is amazing what a
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 01-08-2012, 02:16 PM   #3
Tried that 4 months ago. Put rv slide lubejmn b=[-baQ on everything. Put a whole can on 4 slides and worked them in and out. No luck. Thanks however.
Old 01-08-2012, 06:49 PM   #4
Dallas Texas
Be sure the trailer is level. Slides aren't as balanced as we think they are and need/require the unit to be level front to back, side to side.
Also be sure the battery is fully charged, even if you have shore power connected
2003 Cardinal 33CKT
2006 Ford SD F250 CC 4WD
2001 Coleman Santa Fe (to be sold)
1984 Honda Magna V65
1963 M50 Harley Davisdon
TexasBBQ is offline   Reply With Quote
» Online Users: 659
154 members and 505 guests
11XLITE28BH, 4bnabird, 64c10, alphadog99, alpinemike, autorot8, BigKidzFun, Bigmatt, BigR, Bingo71, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bush, bwbarnes, Cafjackracing, camper1953, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, creed, CRZ, Csbower, cstover, cyclepuck, Dakota EV, dapersico, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, djorgensen3, dnaraG_1M, doc73, donh, donn, doosterhouse, drobert, DTingle, EL99jl, emljr, extremebike, feerobk, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itat, itech, Itsthetwoofus, Janet H, jar3316, JedinWI, jerrygallion, jjm901, jmswms, jobren4, Juan.Cortes, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, lbhird, ldprice47, LFugate, lochsa, LuckyMcBRIDE, mbfree66, melbornj, mhartzel, Michigan, Mickey1, mike2tall, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Papa Roo, pgordemer, pg_rider, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, rob2112, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, trailraider, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wagon52, wellcoman, whj77372, Wildcat Chris, win, y01lxb
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
