04-09-2011, 12:36 PM
Sandpiper wiring short
A short developed in my 2002 Sandpiper during last trip to Utah. The running lights immediately blow a fuse when plugged into truck.The brake lights and turn signals are O.K. Anyone have tips where to look? Any help would be appreciated.
04-09-2011, 01:03 PM
Moderator
I think I would start with the easiest to get to, and that would be the rear lights to see if there is a short in the bulb socket or wires. With lights off, you could check continuity between the hot wires and trailer ground....that should indicate a short. If no luck there, then you will have to start on the marker lights.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
04-09-2011, 01:18 PM
My first thought would be to remove all the bulbs. Connect and try. If it doesn't blow the fuse start putting the bulbs in one at a time, testing each time you put a bulb in. If it blows the fuse with no bulbs in, I would start with a detailed troubleshooting inspection of the wire harness from the truck to the trailer. Good luck and please keep us posted.
Kirk, KN1B
2011 Flagstaff 26RLS
2000 GMC Sierra 1500
04-09-2011, 02:04 PM
check the little box where the cable from the truck goes in; should be a strain relief around the cable, see if it is pulled out. u could be making contact inside that box. that should be fairly easy to get out of the way. i'd start with the movable wiring first. may be a bit out there, but the inside of the female end of the cable could have a wire touching.
if that isn't it, kbrown has a good suggestion.
04-13-2011, 03:43 PM
Thanks to all for your help. I think we have found the problem. When the trailer was built, the wiring guy carelessly ran the wires thru the scotch locs and an exposed a hot wire --it seems the wires jiggled until they shorted on the aluminum siding. As soon as we pulled the lights and wires out and exposed the scotch locs the short was gone and all lights work. We will redo the scotch locks and the problem should be solved. Hopefully there are not more lights like it.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 661 |
| 154 members and 507 guests |
| 11XLITE28BH, 4bnabird, 64c10, alphadog99, alpinemike, autorot8, BigKidzFun, Bigmatt, BigR, Bingo71, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bush, bwbarnes, Cafjackracing, camper1953, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, creed, CRZ, Csbower, cstover, cyclepuck, Dakota EV, dapersico, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, djorgensen3, dnaraG_1M, doc73, donh, donn, doosterhouse, drobert, DTingle, EL99jl, emljr, extremebike, feerobk, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itat, itech, Itsthetwoofus, Janet H, jar3316, JedinWI, jerrygallion, jjm901, jmswms, jobren4, Juan.Cortes, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, lbhird, ldprice47, LFugate, lochsa, LuckyMcBRIDE, mbfree66, melbornj, mhartzel, Michigan, Mickey1, mike2tall, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Papa Roo, pgordemer, pg_rider, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, rob2112, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, trailraider, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wagon52, wellcoman, whj77372, Wildcat Chris, win, y01lxb |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
