The satellite coax is ran directly from the F connector on the outside of the RV to the F connector on the inside plate. The cable coax is ran from the outside F connector to a connector on the power supply/switch/splitter. So you'd hook the dish to the satellite F connector on the outside of the RV and then you'd hook the receiver to the 'sat' F connector on the wall plate. Then you'd have to run a cable from the receiver to the tv.
Gotta go campin!
