10-28-2011, 08:44 AM
Originally Posted by onetonford
Iggy I have made one from 1/4" plastic sheet like you use for windows I used four conduit clamps attached to the sheet that clamp to the ladder side rails so I can mount to either the top rails or the back rails I wish I had photos will have to get some to show anyway I used the original tube and mount to the plastic It also has the level built in so I can level it so far has worked in most places we have been.
I would love to see some pictures. Can you use it no matter what direction you park?
Here is the one I made yesterday for my large dish.
2012 Georgetown XL 37' - Model 378TS Dinghy - 2012 Fiat Pop 2,323lbs
10-30-2011, 11:04 AM
I made one of those and filled it with sand. Mine has 3 legs do it won't teeter. I threw it on the roof at a BBQ contest in Kansas City in a wide open parking lot with some pretty stiff winds and it never moved all weekend. That's the part I like most and it stows easy.
10-30-2011, 12:25 PM
Like your GREAT IDEA about filling it with sand.
I think I may do that but with everything sealed I need to sut and open it up.
10-31-2011, 12:16 PM
Originally Posted by DAISY BOYKIN
Here are the three pictures.
SID
To get your signal from your SAT to the TV dis you have to do any MODs?
Did you hook it up to the SAT connection on the outside?
Where did that feed go inside and how did you hook up your receiver?
Iggy
10-31-2011, 12:33 PM
Originally Posted by Iggy
SID
Iggy
I use the satellite feed on the exterior of the camper. I connect the receiver to the cable outlet from concertone, set the tuner at AV1, and the TV input set to cable. Voila , picture perfect, well almost, except for the poor quality signal created as it passes through the concertone tuner. Video jumping.
Terry/Bernadette Lily the Yorkie 2010 RAM 2011 Flagstaff 8528 CKWS
10-31-2011, 01:06 PM
Rugged Brown thanks for your anwser.
I undertstand.
Use the satellite feed on the exterior
I'm not sure what you mean.
Connect the SAT receiver to the cable outlet from concertone?
Is this the one connection in the cabinet below the TV?
I understand this set the ZX700 tuner at AV1, and the TV input set to cable.
Do you mean you by passed the ZX700 and went straight to the TV?
10-31-2011, 01:12 PM
See below
I undertstand.
Use the satellite feed on the exterior YES
Is this the one connection in the cabinet below the TV? YES
I understand this set the ZX700 tuner at AV1, and the TV input set to cable. YES, Pretty sure it was the Cable setting on the TV. Not 100%. You may have to try a couple of available input settings to be sure.
Do you mean you by passed the ZX700 and went straight to the TV? NO, I used the ZX700 Tuner
10-31-2011, 04:34 PM
This is my sat hook up--------
This is my sat hook up. As you can see I made two small jumpers that I leave in the 5ver when I remove the receiver. If you also hook up CABLE there is no more connection other than the hook up out side or using the roof antenna. You have to select ant or cable/sat in the TV setup and do a channel search.
The cable on the left goes to "SAT IN" and the one on the right is "OUT TO TV"
I also use a audio RED/WHITE/YELLOW cable for the surround sound, as you can see in the white plate connection. The red/white/red cable also plugs into the sat receiver.
As you can see, I use key tags to label the cables so there is no screw up from bad memory!!!!!!!
I also have two old CB antenna magnets attached to the top of the cabinet interior to stick my receiver to when it is installed in the cabinet. I just leave the cabinet door open so the remote will work.
Sid & HRH- Daisy the Boykin.
2011 ROCKWOOD 8285 WS
2005 F-150 SUPERCREW
SUPER GLIDE HITCH
10-31-2011, 05:33 PM
My camper only has the one hookup on the outside for the tv. I didn't really like that with all the other stuff it does inside the walls so I drilled a small hole out the bottom of the tv area into the front storage area. I disconnected the coax from the tv in plate on the outside of the camper and connected my own. That way I have 1 wire going straight from the dish to the receiver. Great picture quality.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 662 |
| 155 members and 507 guests |
| 11XLITE28BH, 4bnabird, 64c10, alphadog99, alpinemike, autorot8, BigKidzFun, Bigmatt, BigR, Bingo71, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bush, bwbarnes, Cafjackracing, camper1953, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, creed, CRZ, Csbower, cstover, cyclepuck, Dakota EV, dapersico, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, djorgensen3, dnaraG_1M, doc73, donh, donn, doosterhouse, drobert, DTingle, EL99jl, emljr, extremebike, feerobk, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itat, itech, Itsthetwoofus, Janet H, jar3316, jechst, JedinWI, jerrygallion, jjm901, jmswms, jobren4, Juan.Cortes, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, lbhird, ldprice47, LFugate, lochsa, LuckyMcBRIDE, mbfree66, melbornj, mhartzel, Mickey1, mike2tall, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Papa Roo, pgordemer, pg_rider, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, rob2112, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, southernsky, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, trailraider, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wagon52, wellcoman, whj77372, Wildcat Chris, win, y01lxb |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
