09-10-2014, 10:11 AM
Scissor Jacks
Is there a way to make a set of scissor jacks that have the hook crank into a set that you can use a nut driver or socket on? Can the threaded bolt be taken out and replaced with one that a socket can be used on?
Or do I have to replace all 4 jacks to get what I want?
09-10-2014, 10:28 AM
I'm sure you can cut and weld what you want on there, or if your jacks are similar to the type I had, I was able to use an allen wrench in a drill and it worked just as good as the type that use the 3/4" socket
09-10-2014, 10:31 AM
Thats what I did on our first TT that had that kind of stab jack on it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
09-10-2014, 10:42 AM
The slot you put the hook into is round on mine, I don't see any way to get an allen wrench to bite on anything in it.
09-10-2014, 10:48 AM
[IMG]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBhUTBxQVFhUXFxsbFBgWGR4cGxoeHx4XGhcYFx YaIighJB8lHxocIzchJSksLy8uIx81ODMsNygtLywBCgoKDg0O FBAQGywcHx0sNCwsLCwrNywsLCwsLCwsLCwsKywtKywsLCwsLC svKyswLCwsLCwsLCwrLCwsKywsLP/AABEIAGwBGAMBIgACEQEDEQH/xAAcAAEBAQADAQEBAAAAAAAAAAAABgcDBAUBCAL/xABEEAACAQIDAwYJCAgHAAAAAAAAAQIDEQQFBhIhMQcTYXGBkS IyQVGCocHR0hYjM1JykpOxFBUXQkNEwuElNFNic4Oi/8QAFgEBAQEAAAAAAAAAAAAAAAAAAAEC/8QAGxEBAQEBAQEBAQAAAAAAAAAAAAEREjECYUH/2gAMAwEAAhEDEQA/ANxAbtxPl0+AH0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAyXXWc4+Ov6FLLq1RLnaSlCEmk+DknFcekluDWgAUSvKXh 8wxWl5RyqMpyco3jFbTavv3LsMfVHP8ACPw6VeH/AFzX5WP0UDP186uvz5TznNaX0lXER/E9rPSw2p8xh/PTj9q/tNvlCE/HSfWjgnl+CqePSpvrivcZ4/TWV4fU+cP6LHU39qN/6T0KWp9S823GthZ2Te9pcFfypFzW05ktf6XD0n6COnV0Vpyqmn h4K/HZvHjx4MvNNdHS+ucHm+xTxlqdVqN7PwHJ+SLvdX8ifrK4zrlG yPD5dk1KplkYwjSkk1FWsmrbnx8nDz2ZYaWzT9c6fo1nxlHwut bpetFlu5R6oANIAAAAAAAAHl59neHyXDKVa8pPxIri/wC3SeoQGFxUs+1bNR3xV4p/Vpr6RrpleMV9qXmJasc+P1DnqpRlgoc6pK6WGpOoo+baqN2v1H SjqDVsv5fFfgU/bM0KlThRpqNJJJKyS4I/sYM/o5tqytPfSxMV55UaXsmz0aUs/qRvUqV0/NzEPeV4GGpJ088/1cR+FD3nHOjqB+JUxH3Ka9pYgYahamG1b/DqVO1Q9jOF4PWrluqSt6PxGgAnJrPnlutJ8a01934j5SyTV7j8 9ianZs/GaEByagPk7qaS34mt/wCfjPq0xqBrwsTX+9H4i+BrIagPknnje/FYn8SK94+RmbSXh4vFdlaPwF+BkNQtPQ+Kf+YxOJn0OsrPrtC5 6Wn9IUMsxPOYjm5STvBRhbZe/ftybk3Z+dLoKgDIaAAIAAAAAAAA8jVmDWO07Wha/gNrs3+wkORPHupktfDze+hXdvszW1F9+0uw0WUVKNpcHxMg5PW 8j5TMRh6nCrTaXS6UnZ90mZvsVsAANIAAAAAAAA8zUmOWXZLUn ez2bJ9L3XJ3k0wE6WFq1qy3zkoroUbtr70muw+co2LT5qjxW+p US8qjwXbaS7UVGR4J5flNOnLjGK2umT3yfe2Z9q/x3gAaQAAAAAAAAAAAAAAAAAAAAAAAAAAAAADH9aXyLlLw+J4R5 2Lk/wDbNbEvebAZhy35fKrlsKlLilKParSh+UjP14saeDztO49ZpkN Cst+3Ti3123+s9E0gAAAAAAHRzzGrLspqVG7bMXbr4L1gR1K2e atnJ74qooR+zTtOo+q6pr0mX5IaCwUqVNyqLxYRir8VKfzlT1O mvRK8ki0ABUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnNf4WOJ03 NyV9iUZdl7S9TZRnWzPCrG5dUpv9+Eo96aRLNgkOR+vP5JczV8 bD1alJ+jLwfU0XBnPJ3X/AEbVWKpS/j0qNdLzS2dip3v8jRhPAABQAAAk9dVYV5UMNN+DUnt1v+OG+d+ tX7isIjEJZtqWrtq8dqOGh66ld9WyrdO00SrFPkNGpSyuLrq05 3nNeaU3tNdl7dh6ABUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AABmuMX6m5QcHNboznXw8u3Zq0l3Tkuw0ojuULKaONy+85OnJV KdSlV8kKkL7Lk/Imna/edWtrfOMNGKqYCpKSXhSTezJ+em4xkrPr95NxV2CCfKFjYL57A VV6UvbTP5/aUo/SYSovTXtSJ1DF+CBjyn4T97D1fvQ95yftOy2K+coV11c2/6x3DFjmeMjl+X1KtThCLl3LciY0Tg5KcZVd7hTvJ+epWaqTb6V BU12sndUa7wueYCNHK6dWSnvqx2bSsnbYSV9zfGXDha9915pjA YjAZUv05p1ptzqtcNqXkXRFWiuhIS7R6wANIAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAD5OMZxamk0+KZP4vStGcv8Nq1MNF73 Ciqey39a0ou3UrIoQBF1tDYupK8cyxa6PAt3RijqV+TvMavi5p il3+u0kX4JhrMK3JdnM5PZzau7/WjJ26vnTjwfJfnOE3PH85F8VONRX7VUNTA5i6nNL6OyvT950Kc eenbnJq9m1wspN7l5PKUYBUAAAAAAAAAAAAAAAAAAAAAAAAAAB//9k=[/IMG]
09-10-2014, 10:49 AM
Ha, what the hell is that, I was trying to post a pic of it.
09-10-2014, 10:50 AM
Its called a hook style scissor jack. They make a drill accessory for it, but I would rather use an allen or a socket.
09-10-2014, 10:56 AM
An L shaped allen wrench would go through the whole in place of the hook. I guess you could cut the hook off but if it is rounded the drill chuck probably would not grip it very well
09-10-2014, 10:57 AM
I got ya, did that work alright when you did that? I'll give it a try.
09-10-2014, 11:05 AM
I used a larger allen wrench that filled the whole. Worked great for me and definitively sped up the process. My drill was an 18 volt with 1/2" chuck. It has two speeds and I used the slower speed with more torque
09-10-2014, 11:08 AM
Awesome! I'll give it a try. Thanks for the help.
