Old 03-04-2010, 04:52 AM   #1
Second Thing To Check Before Camping Starts
FYI, The plumping lines to your sinks under the counters sometimes may loosen from the cold weather and especially where the water supply is connected to the camper (City Water Connection) This one thing to check If you have a new camper and are waiting for Spring and have not used your new rig yet. If you do check them and find them loose remember do not over tighten them just make sure they are snug. While you are under the sinks you may want to check the traps as well, I had one that came loose at the bathroom sink and it began leaking on the floor under the cabinet. Just a thought......
Old 03-04-2010, 06:13 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Thanks for the reminder. That's one thing we take for granted until it does leak and then you ask yourself "Why didn't I check that?" I will add one other thing is put in new batteries for the CO detector and smoke detector. I hate waking up to one of those things chirping that the battery is low.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-04-2010, 07:48 AM   #3
Yes, Batteries that 's the first thing I do when camping season is over is to remove all batteries for the Winter and when it's time to get the camper ready for the season, I install all new. Thanks for bring that up Charlie....
Old 03-04-2010, 10:25 AM   #4
NWJeeper's Avatar
And I just have to believe that they are built with internal clocks so that they will only chirp at 1:00am. Once had one that continued to chirp after removed from the AC power and the battery removed. Threw it out the window into the front yard at about 2:00am.
Good reminder Rockwood06.
Ed & Wendy
www.nwjeepn.com
Old 03-04-2010, 10:46 AM   #5
MtnGuy's Avatar
Speaking of chirping smoke detectors, mine is doing that, and the battery shows good. Any thoughts before I change the whole thing out??
Old 03-04-2010, 10:59 AM   #6
cfsoistman's Avatar
Check for dust or spider web. Try using a small paint brush after removing the battery and then reinsert battery and see if that doesn't correct the chirping. Mine did the same thing last year. If it doesn't chirp, great, but still push the test button to be sure it works.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-04-2010, 11:02 AM   #7
MtnGuy's Avatar
I will try those ideas. The last time I checked, there wasn't anything visible, but it won't hurt to dust a little.
I have just figured out that my smoke dectector chirping is probably why the birds like my camper so much !!!
Old 03-04-2010, 11:11 AM   #8
cfsoistman's Avatar
They usually like mine right after I wash it, same thing goes for my car.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-04-2010, 01:37 PM   #9
I first time I winterized my 06 RockWood I forgot to take out the battery in the living area. My neighbor next store had his fire place going and the smoke invaded the camper and the smoke detector went off, well the problem was that the detector is mounted on the ceiling and it was over the slide out and could not reach it and the side with the slide out was on the garage side and could not open it so I had to let it die. That's one reason I take them out before winter, I learn my lesson.
Old 03-04-2010, 01:52 PM   #10
cfsoistman's Avatar
Hopefully it wasn't an Energizer Battery. I manage to remember the Smoke detector but it's the CO detector I usually forget, probably because it's a pain to slide apart. The first time I changed that battery I found that FR used one screw to mount it. Lets just say it's a good thing I was out there by myself because all I could get it to do was spin. I was worried I'd tear the padded ceiling material. I was ready for a padded room myself. It finally slid over just slightly where I could use a scratch awl and pry it the rest of the way. Once I saw the type screw they used I realized why it wouldn't slide. That must have been the day they handed out Big Round Head Screws and the detector was stuck on it. I replaced that screw and added another pan head screw so it slides over without getting stuck.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
