Old 03-05-2011, 03:53 PM   #1
Captain Ron's Avatar
Securing and protecting a generator
Our new toy hauler has a spot on the tongue for a generator. I have a Honda 3000is Handi that I am thinking of mounting there. For those who have a generator on the tongue, how do you secure it (both for traveling, and against theft)? Also, i can get a protective cover for the generator, but the generator shelf is expanded metal, so road dirt, etc. could still get on the generator from below. Besides getting a piece of sheet metal and covering the expanded metal, are there any other solutions?
Thanks!
...ron
2011 Wolf Pack 19WP
2015 Ford F250 XLT CC SB 4X4 6.2L 3.73
Captain Ron is offline   Reply With Quote
Old 03-05-2011, 04:19 PM   #2
Send a message via Skype™ to scubieman
I would take some kind of bolts and bolt it on there. Then I would take a welder and weld the bolts so the nuts can't come off. The only way to get it off then would to grind the bolts. I maybe put between 4-6 bolts to hold it on and maybe weld 2 - or all if you don't feel safe.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 03-05-2011, 04:28 PM   #3
DAISY BOYKIN's Avatar
Outa sight---outa mind !!
Captain RON, put that sucker in the bed of the truck out sight. Your type of generator is a high theft item. These days It would get probably just enough $$$$ for a crack head to stay high for a couple of days.
You mount it on the tongue, vibration through the TOY HAULER. You are a trusting soul.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-05-2011, 04:49 PM   #4
MotocrossCamper's Avatar
If they can get that off to steal it then they deserve to have it! It would be easier to try and steal the whole camper!
You can but 3/4 inch rubber pads between 2 fender washers and it will take away a lot of the vibration, there really isn't that much on a Honda any way.
MotocrossCamper is offline   Reply With Quote
Old 03-06-2011, 10:15 AM   #5
Thanks! We carry it in the bed of the truck right now, so that is still an option. I can set it on the platform on the tongue when we need it. I hadn't thought about the vibration, so if I do anything I'll add rubber for insulation.
How about the battery (ies)? Do folks secure them against theft?
...ron
2011 Wolf Pack 19WP
Old 03-06-2011, 01:14 PM   #6
acadianbob's Avatar
Hmmmmmmmm. Somehow I never stopped to consider that. And I have a nice $100+ Trojan just sitting out there ripe for stealing . . .
You would almost have to use a cable and padlock. Then getting the length just right might be a trick . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-06-2011, 01:29 PM   #7
bikendan's Avatar
just a comment on the 3000 Handi.
you do know it is way louder than the other Honda inverter generators, right?
that's one reason it isn't selling that well. i would never spend that amount of money if it wasn't on the same level of quiet, as Honda's other generators.
but if you're boondocking, then it'll work great.
Old 03-06-2011, 03:39 PM   #8
Thanks for your concern. We've been using it for two years and haven't received a complaint yet. The weight savings of the 3000is was a big benefit with out old trailer, which was getting close to the weight rating.
...ron
2011 Wolf Pack 19WP
Old 03-11-2011, 10:48 PM   #9
Captain Ron, I found and purchased these neat little gizmos for securing my tongue-mounted batteries...seems pretty secure...
B & D RV Battery Lock For RV travel trailers and popup campers.
LoryJ is offline   Reply With Quote
Old 03-11-2011, 10:50 PM   #10
Bookmarked!
Thanks!
...ron
2011 Wolf Pack 19WP
