Old 07-07-2019, 09:41 PM   #1
Securing Grab Handle
Anyone have luck securing the grab handle? Mine has two screws that go through sheet metal. I tried hallow wall anchors that appeared to require zero debth. Additionally, I Crazy Glued then anchors as well as the screws but now its looser than when I started.
Thanks for any advice you may have.
Skip12 is offline   Reply With Quote
Old 07-09-2019, 07:36 PM   #2
mikkeeh's Avatar
Well......first, what camper do you have? What grab handle are you talking about? Front door? Interior? Bathroom?
Way too many variables for a helpful answer.
mikkeeh is offline   Reply With Quote
Old 07-10-2019, 06:21 AM   #3
SilhouettePenny's Avatar
Can you get behind the surface to add additional support? On some exterior walls it may be possible to remove a panel inside and reinforce the mounting area. Interior grab handles are easier because you cut 2" holes behind the mounting surface and add 1/4" plywood then molly or toggle bolts to secure.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
