Old 10-26-2010, 12:24 PM   #1
The Old Man
Willis's Avatar
Service tech - idiot or just didn't care?
During pre-delivery testing of my brand-new Flagstaff TT last summer, a service tech discovered a minor leak in one of the fittings near the city water intake. The water pump and filter are in this same very cramped and difficult to get into area in a corner of the bathroom. After much difficulty he pulled out a PVC Tee fitting which he said had a small crack in it.
I had purchased a winterization bypass kit and so asked him if he could just replace the fitting with my bypass valve. He said "sure, that's easy and will save you some work!" Which was my thinking exactly...
Now this last week I was going to use the bypass for running antifreeze through the system. I crawled into the corner and found the valve...but the idiot had put the valve on the OUTPUT side of the pump. That is, it's between the city water inlet and pump. Idiot.
I did blow all the lines with my compressor anyway, so I'll have to be content with that until I can buy a new bypass valve and put it in correctly. I guess as always, if you want it done right you have to do it yourself.
The image below shows the correct setup...
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 10-26-2010, 12:45 PM   #2
He thought you would later be putting a second pump right before the valve just to winterize
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 10-26-2010, 07:09 PM   #3
yvesm's Avatar
They are mostly idiots, and then they don't care
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 10-26-2010, 08:32 PM   #4
camping
tentcamper1's Avatar
as yvesm says and also most don't have or get any training. most of us know and understand the systems better than the techs.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
