Old 07-27-2016, 09:12 PM   #1
Several control panel switches stopped working
Hi,
Wondering if you can help me locate a problem. A few days ago several light switches on the top row of my Sandpiper 365SAQ control panel stopped working. Namely "kitchen", "porch" and "scare". Can't find any breaker or fuse that is not working. Was wondering if there may be an inline fuse for this and where I might locate it. I tried looking behind the control panel but couldn't see one.
Anyone else had something like this and fixed it?
Thanks in advance,
Sahgie
2006 Chevy Silverado 3500 CC LT1 Dually
2011 Sandpiper 365SAQ
B&W Companion Hitch
Sahgie is offline   Reply With Quote
Old 07-28-2016, 11:12 AM   #2
Head Rambler
If you have a multimeter you should check for 12 volts feeding the switches and at each switch that's not working. If you have +12 volts at and through the switches, then you'll need to start looking for a open negative somewhere along the line.
Gotta go campin!
Old 07-28-2016, 11:20 AM   #3
Mr. Dan's Avatar
I'm thinking along Rambler's lines- I'd look for an open ground.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 54; booked = 14
Old 07-28-2016, 11:30 AM   #4
SeaDog's Avatar
If you haven't pulled the switch panel you may want to do that and check the connection that was made tying the 12V to those switches they are only crimped connections
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-28-2016, 01:38 PM   #5
Switches
I had the exact same problem and, after checking everything else, I ordered new ones. The only place that I could find that sells the exact same ones is BURNSTINES DISTRIBUTING, BRISTOL IN. The lady on the phone was extremely helpful and there was no problem. The new ones work great.
VMI'62
Edmund is offline   Reply With Quote
Old 07-28-2016, 01:44 PM   #6
Check these tiny black buttons
Those black buttons on the left of this panel are actually reset switches. This is by the batteries.
http://www.forestriverforums.com/for...1&d=1469731346
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 07-28-2016, 07:42 PM   #7
I've had it happen to other 12v switches and it turned out to be a loose ground connection.
DrLewie is offline   Reply With Quote
Old 07-28-2016, 08:42 PM   #8
X2 - I had the water pump switch quit working. The pilot light on the switch was on, but no power to the pump. I pulled the switch panel off and found the +12 that feeds all of the switches had come out of the crimp.
2006 Silverado 2500HD
2014 Flagstaff 21FBRS
bcmcdonald is offline   Reply With Quote
Old 07-28-2016, 10:08 PM   #9
Thanks guys for all the suggestions. Seems to me like a loose 12v also as it affects only these three switches and it happened on all three all at once. I did have a quick glance initially and couldn't find anything wrong with the wiring behind the panel as well as under the fridge where most of the cables go.
I bought a multi,enter today and will have a check with it and will keep posted.
B&W Companion Hitch
switch
