Old 07-08-2009, 08:07 PM   #1
Shockwave Shower problem
So I just purchased a 28ft shockwave fifth wheel. Took it out for it's first trip fourth of July weekend, everything went well with the exception of a few breaking in issues. The main one that has me stuck at the moment is the shower, the tow kick plug that is at the bottom of the tub is stuck closed. Water does slowly drain but a 2 minute shower leaves most if not all of the water still in the shower. I'm a little stumped on how to fix this. Any ideas??
titan4486 is offline   Reply With Quote
Old 07-09-2009, 11:14 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I can't speak from experience with the toe kick you're talking about in your RV but I've seen something similar in residential bathrooms. To release it you just push down to open and push down again to close. The opening is adjustable by unscrewing the drain plug to allow a greater distance from the plug to the tub bottom. If you don't use the tub to bathe in I'd remove it entirely and install a grate over the opening with a screw.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 07-09-2009, 08:24 PM   #3
I tried to push it back in but no go. I'm pretty lost at this point.
