Forest River Forums
Sunline User Photos
Old 04-11-2011, 05:37 PM   #1
Shore Power
Once you are set up at the camp site and plug into power can you disconnect the battery. Does the battery supply power to anything else except jacks?
06 Rockwood 8285SS
97 Z71 Chev
Firestone Air Rides(thanksYouroo)
2010-33 nites
2011-41 nites and growing
2012-18 with more to come
kscr4 is offline   Reply With Quote
Old 04-11-2011, 05:38 PM   #2
Oh yea forgot about the slide but that would be out also.
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 04-11-2011, 05:56 PM   #3
sherdep's Avatar
inside lights as well since they are running off of 12Volts as well
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-11-2011, 06:23 PM   #4
That's kinda what I thought too, but last weekend I was doing a mod to the lights above the bed. I disconnected the battery thinking I was cutting power to them but they remained on. The only way I could get them off was to disconnect from the house power.
06 Rockwood 8285SS
97 Z71 Chev
2010-33 nites
Old 04-11-2011, 06:28 PM   #5
kalik282's Avatar
You should have a breaker in your panel labeled "Converter". Turn that off and the 12V side will be off. Saves having to unplug from 120V.
OTOH, why would you want to disconnect your battery? While you are on shore power, your converter is keeping your battery charged. And, if there is a large need for 12V, your battery is there to assist your converter.
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=2
kalik282 is offline   Reply With Quote
Old 04-11-2011, 11:14 PM   #6
Location: Jacksonville Florida - Home of the Jaguars !!!!
Just as a side note; you will eventually burn out your converter if you do disconnect the battery, because the converter is built to charge the battery and provide 12volts to many different systems in your camper. It will be trying in vain to charge something that isn't there, and they aren't cheap or easy to replace, either. Best bet to leave it connected, and keep distilled water in it to the top of the plates. Just my humble opinion! Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
Old 04-11-2011, 11:32 PM   #7
Moderators' Assistant
bikendan's Avatar
yea, i'm also wondering why the OP wants to disconnect the battery, since it'll probably need some recharging.
Old 04-12-2011, 07:52 AM   #8
Lou Amadio
herk7769's Avatar
Rather than mess with cables every time I need to work on the electrical system I put in a disconnect switch when I rewired the battery compartment.
Also using a high voltage de-sulphating 4 stage charger I would disconnect to avoid running 12 volt dc appliances at de-sulphating voltages.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 04-12-2011, 08:20 AM   #9
jimh's Avatar
do u have one of those big red keys near ur fuse box? doesn't that disconnect the converter and all but the slide outs and maybe the jacks from the battery?
still don't know why u would want to disconnect...unless ur wanting to change the bat; it also acts as a filter.
if u have this switch, u can disconnect the pos lead of the battery (with shore power disconnected) then plug back in and check for voltage at the disconnected lead. that should let u know if that disconnect really isolates it from the fuse panel and converter/charger.
jimh is offline   Reply With Quote
Old 04-12-2011, 08:45 AM   #10
volunteer moderator
I don't believe this is true.
The charger is loafing when nothing is connected so it
won't over heat and "burn out".
OTOH, I see no good reason to disconnect the battery
unless you are permanently parked and full timing.
Not even sure if you'd need to do it then.
Just check the water ever couple months.
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
KyDan is online now   Reply With Quote
» Online Users: 673
158 members and 515 guests
11XLITE28BH, 1l243, 4bnabird, 64c10, alphadog99, alpinemike, anitag, armye7, autorot8, Bearcat55, BigKidzFun, Bigmatt, BigR, Bingo71, BlakeB, bob34787, BonnieSeip, boubou, bowtang2001, bush, bwbarnes, Cafjackracing, Cairdeas2111, camper1953, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, creed, CRZ, Csbower, cstover, cyclepuck, Dakota EV, dapersico, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, djorgensen3, dnaraG_1M, doc73, donh, donn, doosterhouse, drobert, DTingle, EL99jl, emljr, extremebike, feerobk, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itech, Itsthetwoofus, Janet H, jar3316, jechst, JedinWI, jerrygallion, jjm901, jmswms, jobren4, jordan, Juan.Cortes, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, lbhird, ldmcmahan, ldprice47, LFugate, LuckyMcBRIDE, Maddog378, mbfree66, melbornj, mhartzel, Mickey1, mike2tall, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Papa Roo, pgordemer, pg_rider, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, southernsky, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wagon52, wellcoman, whj77372, Wildcat Chris, win, y01lxb
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
