Old 09-08-2011, 05:37 PM   #1
NONI's Avatar
Shortstop or Circuit Breaker
We have an issue where the battery is fully charged, but nothing runs in the camper. When using AC shore power the camper works fine. I pulled out a multi-meter and check the battery, great power 12.9V. Checked all fuses no issues. Checked electrical and tested a small circuit breaker located between the battery and a junction box that goes into the camper. The part is a shortstop 24V S34 40A, or circuit breaker.
It amazes me that Forest River will install a circuit breaker exposed to the elements were connections corrode and the parts fail. A small plastic or junction box is a quick and easy fix. Anyone has come up with a solution or modification for this issue?
See ya' out there.
NONI is offline   Reply With Quote
Old 09-08-2011, 05:50 PM   #2
Herk7769's Avatar
Noni, part of the problem is that the CB must be located within 18 inches of the positive terminal of the battery. I agree that for travel trailers that is a challenge. A rubber boot would really help.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 09-09-2011, 03:26 PM   #3
NONI's Avatar
herk
Thank you for the idea. I got some rubber boots and dialectric grease. Used some grease inside the boots and around the connections, then put some more after installing the boots. I am afraid they might fall due to road vibration. Will keep an eye and see how they work out. I rather reach a permanent solution than a temporary one.
See ya' out there.
Old 09-09-2011, 05:50 PM   #4
sherdep's Avatar
you could silicone the connections or silicone the boots over the connections as well
I have not looked at mine since mine is fairly new
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
breaker
