Old 03-29-2011, 04:40 PM   #1
Send a message via Skype™ to stevo
Shower lining
We have a Windjammer 2609w with the mid mounted shower.
I noticed the sealant around the top of the shower lining had cracked and was allowing water between the wall lining and the plastic shower liner.
I have resealed this area several times with different products and they have all failed.
I suspect that there is a lot of movement when towing and this is causing the cracking.
I am now thinking of using a molding or rubber seal.
Has anyone else had this problem and come up with a fix?
Stevo
2010 landcruiser 200 V8 TD
2009 Windjammer TT
stevo is offline   Reply With Quote
