Old 03-12-2014, 10:05 AM   #1
Shower Spill-Off
We've just gotten started in a 2104S and had a little trouble with the shower. Water easily spilled over from the shower into a space between the shower and the cabinet. Water then leaked out the bottom of the trailer directly behind passenger side wheels. Is it possible to caulk the gap or is there a better solution? Suggestions.....
dlewis90 is offline   Reply With Quote
Old 03-12-2014, 10:14 AM   #2
PSUFan1's Avatar
I think I've seen where someone has put a small piece of plexy glass at that spot. Hopefully someone can chime in or maybe do a search on this site.
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 03-12-2014, 10:19 AM   #3
EnduroRdr's Avatar
If you can afford it - upgrade to a shower door.
Now on my third camper - this time it came with a shower door - The first one had same standing shower with curtain like yours - I will never do the curtain thing again - exception maybe for a "Tub" type bath like my second one, but if it is a standing shower like yours - once you have a door you will never want that funky mildew growing leaking curtain again -
2011 Work & Play 27UL and 2006 Dodge Ram 2500 5.9 Cummins.
EnduroRdr is offline   Reply With Quote
Old 03-12-2014, 10:35 AM   #4
I caulked that area soon after we picked our 1809S up & haven't had any trouble. Being you know it got wet make sure you dry it well - a hair drier works well.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 03-12-2014, 10:38 AM   #5
wmtire's Avatar
I personally wouldn't want water to get on the cabinet at all. Here is another forum that may give you ideas.
Water leak over shower rim
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-12-2014, 10:40 AM   #6
Thanks...good replies. We will wait until the area's dry before caulking...if we do that. I was also looking at a corner shower/tub guard....not sure, yet.
Old 03-15-2014, 02:04 PM   #7
VinceU's Avatar
If you don't stop the water from getting back there- You'll have floor and cab wood rot in short order.
Old 03-15-2014, 02:33 PM   #8
The easiest solution is to apply some splash guards at the shower walls & get a shower curtain that's almost annoyingly long. Lowes has the splash guards for $16 each. (check lowes.com for Magic White Splash Guards)(Tried to insert a link but was unsuccessful). Use caulk in addition to the adhesive on the back of the guard. I caulked inside and out on the toilet side and did as well as I could on the cabinet side. No run off problems.
PS be sure to get the tall ones. I used 30" and have no problems.
00buck is offline   Reply With Quote
Old 03-15-2014, 03:12 PM   #9
Brother Les's Avatar
You need something to help keep water off of your cabinet side. If you can get a thin piece of plexi glass cut to size for the side of the cabinet, slid all the way to the foor. Use some vecro tabs to hold it on/up and then use some clear shower caulk along the edge of the shower rim and plexi glass.
Brother Les
Old 03-15-2014, 03:35 PM   #10
X2 on your fix Brother Les and caulk up the Plexiglas to the sidewall.
show, shower
