Old 06-19-2013, 05:37 PM   #1
shower surround loose
Hey I have a 2007 survyour 291 and the shower surround has come loose from wall. I tried using 2 sided tape and same thing. And suggestions on how to adhere this to wall
campfun is offline   Reply With Quote
Old 06-22-2013, 04:57 AM   #2
I had ours come loose also and took it back to the dealer (warranty). They put an adhesive like liquid nails and then put six small screws with plastic fancy washers and painted them the same color as surround, calked the edge and it looks great
Goat_7 is offline   Reply With Quote
Old 06-25-2013, 01:52 PM   #3
Do you have pics of what thy did and screws thy usd
Old 06-25-2013, 05:41 PM   #4
Pic
I have the RV stored. but will get them in a couple days
Old 07-02-2013, 09:04 PM   #5
Could u get pics. That be great need to do something soon
Seperates bad when very hot
Old 07-04-2013, 11:26 AM   #6
Pic's shower suround
Hope it helps
Old 07-05-2013, 02:57 PM   #7
Thanks that looks nice and clean mine seperates across top but a few screes might do it. You said dealer did it
Just wondering where to get screw caps
Old 07-05-2013, 03:12 PM   #8
MotocrossCamper's Avatar
Those are plastic pop rivets, not screws. You can get them at any of your local hardware stores. There are many different styles and colors.
MotocrossCamper is offline   Reply With Quote
Old 07-05-2013, 07:21 PM   #9
Ok thanks for info. Will show progress
Would you try to find studs or just put through panel be enough
Old 07-06-2013, 02:19 AM   #10
If I had to guess you are going to have a hard time finding a stud. If it were me I would put them where you think they look best and if it ends up being just through the paneling I would put a little adhesive in the hole before I inserted the rivet.
